Problem when the engine is hot
Hello, i have a problem with my cossy 3door. It´s been stored in my garage for 6 months due to bad winter we have suffered in Mallorca. Now with the good summer time I decided to take out the car for a ride, and I found a problem.
when the car reaches its operating temp, it begins to misfire. It seem the engine don´t accept the boost. When I press the acelerator hard, the engine starts to misfire, then I release the press and press again smoothly, and then it seems the car accept the boost, but not smoothly, it rattles all the time.
If I stop the car, and let the temp down, then the engine goes well until the temp rises, and again the engine rattles.
The engine was rebuild 2 years ago , and I have just drove 1500Km.
Everything is new, every sensor is new, I dont have any Idea of what happens.
So I need some advice of what to do
Thanks
Thanks
i think it will be the blue temp sensor - but it is always good to replace it
i think the sensor is Ł10 so it is cheap
http://cgi.ebay.co.uk/RS-Cosworth-YB...3A1%7C294%3A50
the other thing i was thinking is maybe map sensor, but this wouldnt explain why it only does it when it is hot
I was also thinking map sensor, as others been done, but best not assume that because they are new they work ok, best get metre out and do some measurements.
If the map is reading wrongly it will be more suceptible to weaker mixtures the warmer it is.
I would also check the fuel pressure, the air temp sensor is a little trim, the main corrective is the CTS, so have a good check on the actual received signal, and wiring etc.
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
try living in england!
