2wd or 4wd head. how do you tell?
Old Jul 9, 2009 | 08:35 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Default 2wd or 4wd head. how do you tell?
How do you tell if you have a 2wd or a 4wd head?
Old Jul 9, 2009 | 08:37 PM
rs turbo j's Avatar
rs turbo j
virgin
Bonnet vents i think mate and the 4x4 badge on the side.
Old Jul 9, 2009 | 08:46 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Thing is that the engine came out of a 4wd saph but has a 205 block. Need to know as it has a set of BD14 cams in it and i need to get standard ones but need to know if i got to get 2wd or 4wd cams.
Old Jul 9, 2009 | 08:59 PM
g10ens's Avatar
g10ens
https://passionford.com/forum/genera...-4wd-head.html
Old Jul 9, 2009 | 09:21 PM
costina's Avatar
costina
Live long and prosper!!
2wd has 2 mounting lugs on the exhaust side for turbo hanger
4wd has none but has a oil feed in the centre of head exhaust side
Paul
Old Jul 10, 2009 | 06:15 AM
Apart from the lug the water channels are different, the 4wd consisting of a series of holes, whereas the 2wd has long slits, other differences as said, if in doubt just get 4wd cams, as these fit the 2wd head with the addition of a spacer, so I would imagine no one would make a 2wd cam now just the 4wd type and offer spacers to suit 2wd be a lot cheaper tooling wise.
Old Jul 10, 2009 | 09:23 AM
rsnissan's Avatar
rsnissan
late 2wd heads did not have the slits for the exhaust waterways, that was just the early (3dr) 2WD heads,
oil feed for turbo on the exhaust side for a 4x4 and the turbo hangar on a 2wd plus the water temp senders are located in different places.
Old Jul 10, 2009 | 05:29 PM
Some sapphs had 3 door engines, so that's why some sapphs have these slits.
Old Jul 10, 2009 | 07:43 PM
avinit1rs's Avatar
avinit1rs
AV IT!!!
Thanks for the info chaps. great help. cheers
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
focus2351
Sep 9, 2015 09:33 PM
