Oil WILL come out sorry missed that bit, especially if done with front on ramps due to tilt.
If done on flat I don't think(not tried) that any will come out other than the drips on the drive bit.
cheers tab
i took the dials out to see if the cable was turning and it wasn't. so i put the car on the ramp and took the gearbox end of the cable off and everything seemed fine. put it back together and now the speedo works again
