Fuel pump rewiring?
Old Jul 6, 2009 | 08:24 PM
mark t cos's Avatar
mark t cos
Smile Fuel pump rewiring?
My fuel pump needs rewiring is there a kit you can buy and is it an easy job to do myself.
Thanks
Old Jul 6, 2009 | 09:43 PM
ybturbo's Avatar
ybturbo
Yes it is very easy to do it yourself and you just need a 40A relay, a 25A fuse with holder ,some connectors and wire rated for about 20 - 25A(4 mm2 wire is good). Take + and - supply from battery and put the fuse to the + wire as close you can to the battery and then connect the - wire directly to the pump and the + to the relay power contact. From the relay power contact connect to the pump and drive the relay with the existing pump feed wires. Ideal place for the relay is inside the spare wheel area next to fuel pump inertia switch...
Old Jul 6, 2009 | 10:57 PM
You can also buy the kits off ebay.I rewired mine.I just used the original relay and put a newlive wire from the relay to pump and earthed the pump out on the spare wheel well.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
tib2220
Sep 14, 2015 12:33 PM
