solid brake pedal.....
Old Jul 6, 2009 | 04:48 PM
SWIFTY's Avatar
SWIFTY
Default solid brake pedal.....
any one no what would cause the brake pedal to be solid brakes still work as does the abs and no lights are on the dash. you have to press realy hard and it only moves abit.
thanks
(spelling)
Old Jul 6, 2009 | 06:25 PM
.Ross.'s Avatar
.Ross.
Vacum pipe come off? Have you still got the vacum assistance?
Old Jul 6, 2009 | 06:33 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Mine was the relay under the dash when this happened.
Steve
Old Jul 7, 2009 | 07:13 AM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
Steve
which relay mate, cheeRS carl
Old Jul 7, 2009 | 07:18 AM
dojj's Avatar
dojj
Resident Wrestling Legend
there are 3 of them
either 2 green and one purple or 1 purple and 2 green ones
should be under the passenger side glovebox area by the transmision tunnel on a littl ebrakcet
whats happend is that the pump has pumped up tpp mush pressur einto the system so it needs releasing
it might need a new pressure switch though, in which case, you migh tbe beter off looking for a whole new pump assembly as the fluid tend to corrode the innares and they strip the threads from both the casing and the valve
Old Jul 7, 2009 | 07:44 AM
carl/saff's Avatar
carl/saff
Originally Posted by dojj
there are 3 of them
how do you know which relay has failed ,as pedal goes hard and car will grab under breaking !!!! what does each relay do ? cheeRS carl
Old Jul 7, 2009 | 07:46 AM
carl/saff's Avatar
carl/saff
also does the abs system share power feeds with the fans ? got a wiring diagram ? could this also be the abs sensors ? thanx carl
Old Jul 7, 2009 | 12:11 PM
dojj's Avatar
dojj
the abs is stand alone mate, shares nothing other than the ignition feed from the fuse box with the rest of the cars wiring and where it plugs onto the battery
you just need to swap these relays over and se if the problem goes away or not
Old Jul 7, 2009 | 01:54 PM
SWIFTY's Avatar
SWIFTY
just had a quick look and i have 1 yell 1 green and 1 purple relay and could only swap 2 as one has 5 pins the other 2 have 4, and it didnt make no diffrance to mine. but what i did notice is that if i pumped the pedal when the pump was still running it was softer and i could push the pedal down more, then it got harder and harder till the pump stoped.
Old Jul 7, 2009 | 02:18 PM
dojj's Avatar
dojj
you shouldn';t have a yellow relay there mate
Old Jul 7, 2009 | 02:49 PM
SWIFTY's Avatar
SWIFTY
all the relay coulours match the plugs they are in.
does the coulour make a diffrance then???
Old Jul 7, 2009 | 03:00 PM
carl/saff's Avatar
carl/saff
was thinking why 3 relays ,what does each one do ? cheeRS carl
Old Jul 7, 2009 | 03:24 PM
dojj's Avatar
dojj
powe power and something else, but not sure what unti i get home and look the book up with the stuff in it
Old Jul 7, 2009 | 04:00 PM
TiB's Avatar
TiB
There is also a fuse under there with the relays.. my bet is that has blown or come out.
Old Jul 7, 2009 | 06:47 PM
SWIFTY's Avatar
SWIFTY
i looked at the fuses when i looked ant the relays they seemed ok
Old Jul 8, 2009 | 12:43 AM
TiB's Avatar
TiB
Check the main power plug is clean and connected to the pump properly too.
Old Jul 8, 2009 | 07:02 AM
carl/saff's Avatar
carl/saff
tried a purple relay out of another saff[with working abs system] same part no as mine and my abs light came on and break fluid level warning light came on aswell[mine has never done this].will go to fords and get 3 new relays .
Old Oct 7, 2009 | 06:29 PM
boXXer's Avatar
boXXer
GASH!
hi mate, did they sort the problem? i have a similiar issue
Old Oct 8, 2009 | 06:29 AM
carl/saff's Avatar
carl/saff
NO !!!! Put new green reley in from Ford , 2x purple releys are on back order . abs sensors tested range .9 to 1.1 all four so they seem OK. Pluged in snap-on fault code reader and melted my wiring loom to the abs [ lucky didnt set my saff on fire] some twat had back wired one of the relays to put out the abs light . getting a new abs wiring loom / ecu got new sensors already but mine seem ok [so will keep as spares] what a carry on !!!!!
Old Oct 10, 2009 | 12:56 AM
botters's Avatar
botters
competant bodger
had this once with my xr4x4 caused by sitting in traffic for an hour with my foot on the brakes....DOH!!! pedal went rock solid and took serious effort to stop allthough luckily after i got home (and felt the pump and servo which were damn near glowing lol!) after letting it cool down all was fine. this probably wont help you with your fault but may help other sierra abs owners from doing the same dim witted thing i did lol!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
