fuel regulator
Old Jul 6, 2009 | 10:18 AM
nikki.n.tom's Avatar
nikki.n.tom
Default fuel regulator
whats the best fuel pressure regulator you can buy for a cosworth my standard one is leaking has got a hair line crack in it. So need a new one..
Should i go for standard or aftermarket?
thanks
tom
Old Jul 6, 2009 | 10:23 AM
Miller 3's Avatar
Miller 3
What power you running?
standard will do 500+ unless you want a bit of bling!
Old Jul 6, 2009 | 11:37 AM
nikki.n.tom
not to interested in how they look just what is best for the job.
am running 450bhp but am going to be doing a build soon.
Where is the best place to get a standard one from?
thanks tom
Old Jul 6, 2009 | 11:40 AM
ECU Monitor Enthusiast
As miller3 says, a standard one is the best
Old Jul 6, 2009 | 11:47 AM
Miller 3's Avatar
Miller 3
Give matt lewis a bell mate
01543 448848 http://stores.shop.ebay.co.uk/Matt-Lewis-Motorsport
Old Jul 6, 2009 | 12:08 PM
Bhp is irrelevant, it is there just to maintain pressure(if available from pump).
Old Jul 6, 2009 | 12:16 PM
Miller 3's Avatar
Miller 3
Yes but it is a good guide tho tabs as obviously if the guy was running 800hp then the standard reg would not be able to supply the required fuel
Old Jul 6, 2009 | 04:02 PM
Paul_RS's Avatar
Paul_RS
2wd or 4x4 sierra? As you can't get the 4x4 ones anymore...
I went aeromotive on mine because it makes aeroquipping very easy.
Old Jul 6, 2009 | 07:15 PM
nikki.n.tom
its for a 2wd
have emailed a couple of companys today no one has got back to me yet.
Old Jul 12, 2009 | 09:21 PM
RobertM's Avatar
RobertM
I got one from Graham Goode, it was a RS500 one, you just need to blank of one pipe that normally goes to the 2nd fuelrail.
Old Jul 13, 2009 | 06:21 AM
nikki.n.tom
thanks I have managed to get one now.
Old Jul 13, 2009 | 06:47 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
the thing with std regs struggling to supply fuel is a myth, dont forget the regs dont actually supply anything!
the problem with the std reg in the end, is the fact they cant get rid of enough fuel down the return line, so you end up with excessive line pressure,
imo a good guide is, a single 044 pump will be best off on a std reg,
twin pumps etc will be flowing too much for them to deal with, and you need something bigger
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
