Coil Overs
Old Jul 4, 2009 | 02:46 PM
nice_head's Avatar
nice_head
Default Coil Overs
Ive just brought a set for my 3dr and ive noticed a squeaking noise coming from the passenger rear side, it looks like the spring is hitting the inside of the arch, any ideas on how to cure this problem as its really annoying
Old Jul 4, 2009 | 02:54 PM
Sonic Boom's Avatar
Sonic Boom
Remove coilover, hit inside of arch with hammer, reinstall coilover.
And Robert is most definatley your fathers brother.
Rich
Old Jul 4, 2009 | 03:31 PM
BRAMMER's Avatar
BRAMMER
As above it is very annoying i had the same but didn't hit it with a hammer mine suffered from it when the car was too low.
Old Jul 4, 2009 | 03:46 PM
nice_head's Avatar
nice_head
When i first got them on there wasnt no noise but when I lowered it like you said it started doing it but why does it only do it on one side?
nice_head's Avatar
nice_head
Rich
lol i think i can hear that hammer calling
Old Jul 4, 2009 | 03:48 PM
chameleon's Avatar
chameleon
have you fitted a rear strut brace?
Old Jul 4, 2009 | 04:35 PM
nice_head's Avatar
nice_head
No I havent, im gathering that might help?
Old Jul 4, 2009 | 05:05 PM
Strut brace would defo be advisable, just a simple bar of metal with a hole in each end would do the job.
The reason why only one side is affected is because of the hideously bad build quality on the cosworths, with them not exactly being "square", and even on each side of the car, the tolerances were quoted in mm's but a mistake led to this being seen as metres!!.
A good bash will soon sort it.
Old Jul 4, 2009 | 08:09 PM
nice_head's Avatar
nice_head
I think im gonna use the hammer option as i dont really wanna folk out for a strut brace if it aint gonna work
cheers for your help guys
Old Jul 4, 2009 | 08:11 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
common issue, the hammer is the way to cure it pal, strut brace wont stop the spring touching the body
Old Jul 4, 2009 | 10:08 PM
chameleon's Avatar
chameleon
no it wont cure it but if you are running coilovers on the rear you should run a strut brace .........they are not strong enough without.
Old Jul 4, 2009 | 11:13 PM
JTECH James
Passion for Fords!
well i did 70k miles without issue on mine,
seam welding the turrets is a good option, running a brace wont be a bad idea, but the cure for the rubbing issue is a hammer lol
Old Jul 4, 2009 | 11:22 PM
chameleon's Avatar
chameleon
sorry mate just thought you were supposed to run a rear brace because of the extra loading on the turrets...........get sally sledge out then........dont bother me my whole car is seam welded ..........
Old Jul 4, 2009 | 11:25 PM
JTECH James
Passion for Fords!
mine was a 4x4, which has stronger rear turrets anyway, so the 3dr may be a whole new ballgame lol
Old Jul 5, 2009 | 07:14 AM
The turrets will be inclined to load sideways, ie tilt inwards under load, this is why a strut brace is a good idea.
I had another sierra on coily's and did 100,00+ in that towing a lot of time 4wd's etc never seen a problem, just run one for peace of mind now.
Old Jul 5, 2009 | 09:40 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
bought some coilies to and a strut brace for good measure. Strut braces arnt that pricy. Got a brand new one from a company on ebay
Old Jul 5, 2009 | 11:19 AM
nice_head's Avatar
nice_head
Are the collies catching on the inner arch or has the strut brace done the trick?
Old Jul 5, 2009 | 04:07 PM
I just bought a length of 1" square tube and drilled a hole in each end!!
Old Jul 5, 2009 | 10:46 PM
johnyjn's Avatar
johnyjn
Hi,if these are gaz coilovers i think you can replace the lower bush with a rose jointed item with some off set top hats which moves the shock out a little bit !
Old Jul 5, 2009 | 11:08 PM
charlie luciano's Avatar
charlie luciano
STOP! Hammer time
Noisey as fook, always on the n/s rear
Luciano
Old Jul 6, 2009 | 12:13 PM
kosienutter
dont know yet i have only fitted the strut brace . was going to fit them today but it is tipping it down. will let you know. plus a mate text me saying that the rear springs might be a pain in the aRSe to get out.
Old Jul 6, 2009 | 12:54 PM
Sonic Boom's Avatar
Sonic Boom
Another easy 3 step guide to cosworth repair;
Plug in angle grinder, cut rear spring in two (right in the middle), remove to halfs of spring.
Saves alot of time and effort if you don't mind scrapping the old rear springs after
Old Jul 6, 2009 | 03:06 PM
cosy trav's Avatar
cosy trav
I wondered what that squeeking was when i fitted my coilovers , now i know .lol
marky_g
Sep 12, 2015 04:26 PM
gcfcos
Sep 11, 2015 06:03 PM
jonfoc
Sep 11, 2015 04:46 PM
dms04
Sep 11, 2015 01:57 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
