Buzzing sounds...
Old Jul 2, 2009 | 06:34 PM
MannheimAlex's Avatar
MannheimAlex
Default Buzzing sounds...
Hi, another month, another weired sound from under bonnet...
This time it is some buzzing sound(like clicking 50times a second) that I found out came from the ICV. That came overnight so I had nowhere my fingers!
That sound appears when I cold start at idle and when warm, when I press the pedal a little bit. when I am driving and that buzzin appears i feel the car accelerates a tiny bit.
So something must give a strange signal to the ICV, but what??
Had also cleaned the ICV 2 or 3000km ago and it`s still seem working fine.
Btw. how do I set Idle right??
Old Jul 3, 2009 | 03:05 PM
MannheimAlex
Well, had it fixed, Turned out the ICV was fooked even though it was almost new...
Old Jul 3, 2009 | 03:12 PM
Theres nothing worse than getting faulty new parts.
Old Jul 4, 2009 | 04:43 AM
AndyPen's Avatar
AndyPen
Yeah, like my brand new Ford water pump - where they hadn't drilled a hole for the inlet - the casting was solid pipe and I HADN'T CHECKED!!
DanS
Jan 31, 2006 07:15 AM
DanS
Jan 30, 2006 05:30 PM
420 cozican
Jan 24, 2006 06:03 PM
Damo V
Ford Escort RS Cosworth
Nov 30, 2005 08:13 PM
The Sludge
May 4, 2005 04:59 PM
