piper or kent
Jun 27, 2009 | 10:55 PM
piper or kent
evening all, im after an upgraded cam for my s2 rs. in your opinions which one is better piper t285 t2 or the kent cvh 35 , cheers
Jun 28, 2009 | 12:59 AM
piper, u might aswell used a half cooked sausage then a kent cam ,seems to be a bit hit and miss if they chew up within the first few months or so!
Jun 28, 2009 | 01:07 AM
try giving newmans a call should be able to help you out and will even grind to your spec if asked.
Jun 28, 2009 | 09:05 AM
Wouldn't wipe my arse on a Piper 285T2, Kent CVH35k all the way, it's a cam I've proven in 3 sperate cars and it works well (as long as you get one from a good blank which is a bit of a lottery).
Newman would be a preffered choice though
Jun 28, 2009 | 06:25 PM
Quote:
Originally Posted by
griffo69
like asking if diarrhea is better than constipation
newman all the way
Jun 28, 2009 | 06:32 PM
ive not heard much about newman, i take it theyre good. how much for a kit iff them . cheers peeps
Jun 28, 2009 | 06:34 PM
Same price as most others, around £300. But you then have the ball ache of fitting solid lifters as Newmans dont do hydraulic.
Jun 28, 2009 | 06:36 PM
this mite be a dull question peeps but whats the point of solid lifters, wouldnt they sound more noisey that hydraulic..... cheers
Jun 28, 2009 | 06:55 PM
I've got a Kentcvh34 kit fitted on mine it's done 14k and had no problems with it so far.
Jun 28, 2009 | 09:37 PM
makaveli96
You pulled it out to check it? Thats the problem with hydraulics, you may not know of a problem as quickly as you would with solids.
Jun 28, 2009 | 10:09 PM
griffo69
Neither, buy a Newman
Jun 29, 2009 | 01:07 PM
had both, both failed due to lobe wear, both run in properly.
newman cam is where it's at.
that'll be my next investment.
Jun 29, 2009 | 11:23 PM
Christian and Beccy
I haven't pulled it out to check it as I wouldn't have a clue how to do it myself but it's been alright so far.
Jun 30, 2009 | 11:42 PM
just fitted a piper cam i was given, see how it lasts
Jul 1, 2009 | 09:48 AM
The Piper 285T2 I took out of my old Escort was worn to fuck, and I mean you could visbaly see the wear and going off the reciepts had only been in the for 16K miles. I've got a Kent CVH34 in mine at the monent which has only done 4k which looks ok but is pretty noisy. I've got a Newman solid lifter ready to go in which certainly looks alot better made.
Jul 1, 2009 | 11:10 PM
Should a cam effect the idle much?
Jul 2, 2009 | 01:14 AM
do tend to make it more lumpy, but not enuff to bother with
Jul 2, 2009 | 07:19 AM
when it warms up does it get a bit worse?
Mc5506
Oct 5, 2015 09:57 PM
cos elle
Sep 25, 2015 09:52 AM
