cosworth woes
Old Jun 26, 2009 | 07:54 PM
daz-cos's Avatar
daz-cos
Default cosworth woes
hi all
whent out in the saph last night an it has developed a bit of a problem. its a bit difficult to explane but al giv it ago. basicly it drives fine off boost but when it comes on boost it will pull for a couple of seconds then it shuts the throtle completely. it doesnt cut out just backs off, if i keep my foot in it will boost up again then back off again. any help apreciated ment 2 b of to coomb next sat
cheers daz
Old Jun 26, 2009 | 09:39 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
actuator spring maybe. see you at combe maybe.
Old Jun 27, 2009 | 05:07 AM
Fuel filter chnaged recently ?
Old Jun 27, 2009 | 01:05 PM
AndyPen's Avatar
AndyPen
Couldn't be the throttle position sensor or wiring could it? Just a guess.
Old Jun 27, 2009 | 09:08 PM
daz-cos's Avatar
daz-cos
tabs dont know bout fillter i havent changed it but dont know bout previous owner?
kossienutter well al be going with or with out the cos but if it makes it al b on south lincs stand
cheers 4 the advice peeps think al get it looked at sounds like it could b a million things
cheers daz
Old Jun 28, 2009 | 12:07 AM
Rollin Rides's Avatar
Rollin Rides
Anyting forsale let me no
boost cutting by the sounds of it. new actuator
Old Jun 28, 2009 | 01:31 AM
jon@work's Avatar
jon@work
things to look at :
check fuel filter - change if it looks old
does this only happen if the fuel tank is only 1/4 full or lower ? if so, new fuel tank required
check fuel pressure regulator vacuum hose isn't leaking/split
check fuel pump voltage
Old Jun 28, 2009 | 10:45 AM
daz-cos's Avatar
daz-cos
sorted
it was the vac hose from fuel reg. some how it managed to come loose even with clips on each end cheers 4 the help thoug guys roll on coombe
daz
Old Jun 28, 2009 | 10:49 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
Originally Posted by daz-cos
sorted
daz
if its a 2wd car you have mate and the vac pipe -fuel reg has come loose
MAKE SURE YOU CHECK THE HOSE THAT CONNECTS THE REG TO THE RAIL ALSO
MELTDOWN WAITING TO HAPPEN IF ITS SPLIT OR LOOSE TRUST ME !!!!
just make sure you check it too
Old Jun 28, 2009 | 10:54 PM
AndyPen's Avatar
AndyPen
sorted
daz
Glad its sorted - will keep an eye out for you at Coombe
Old Jun 29, 2009 | 02:41 PM
Im glad you have it sorted.Its a pain when you have faults on your cossies.
Old Jun 30, 2009 | 08:32 PM
daz-cos's Avatar
daz-cos
t4 - will do mate i dont want that
andy - same 4 u mate
glenny - yea specialy stupid little things that arnt obvious but can cause serious problems
Old Jun 30, 2009 | 08:53 PM
cossiegreg1's Avatar
cossiegreg1
JON can you explain the fuel tank please
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
