if you want one from r&b you have to order at least 6 which is weird when i emailed them. I found mine on the bay. One will come around. They should be still produced. They are more advanced than the first ones that came out with more options.
Thank you. I know that I won't be needing 6 so I guess I'll be looking out for one on Ebay. Does anyone know if I can configure the display to show degrees in F instead of C???
