Cosworth not running right
Old Jun 25, 2009 | 09:21 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default Cosworth not running right
hi guys put this in the technical q-a aswell.
got a slight problem. when i want to come on boost above 10 psi the car begins to stutter and pink out. im am going towards the fuel pump not getting 12volts idea.
am i right or could it be something else?
the boost doesnt drop of.
its a stage 1 4x4. plus it only does it from third gear to 5th cause obviously there less strain on the engine and pump in the lower guys i guess.
__________________
Old Jun 25, 2009 | 10:00 PM
rs2klee's Avatar
rs2klee
K***LMT
check the plug gaps might be open too much
Old Jun 25, 2009 | 10:11 PM
kosienutter
ok will do they are only 6 months old though or can they mess up so soon. cheeRS
Old Jun 25, 2009 | 10:51 PM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
.65mm plug gap with a group a coil for good measure staeg 3 26psi peak no probs mate
Old Jun 25, 2009 | 10:54 PM
carl/saff's Avatar
carl/saff
also mate check crank sensor .65mm again and phase sensor .25mm [phase sensor wiring can corrode and cause running issues] as crank sensor
Old Jun 25, 2009 | 11:08 PM
kosienutter
sweet will look at that was looking a bit grubby when i looked at it last.
Old Jun 26, 2009 | 09:30 AM
When did you last change the fuel filter ?
Old Jun 26, 2009 | 07:31 PM
kosienutter
not sure. Probably a few years ago. Are the simple to replace?
Old Jun 27, 2009 | 05:08 AM
Yes dead easy, make sure you get new copper washers for each end though, as old ones go hard and like leaking when disturbed, note flow direction arrow as well!!
Old Jun 27, 2009 | 10:06 AM
kosienutter
fanastic cheeRS
Old Jun 27, 2009 | 10:13 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Originally Posted by kosienutter
fanastic cheeRS
I have fuel filters and copper washers in stock mate
Old Jun 27, 2009 | 10:49 AM
mechanic28's Avatar
mechanic28
i always find the old seals seal and new ones leak !
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
James Porter
Aug 26, 2015 10:51 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
