comps
Old Jun 23, 2009 | 04:21 PM
fezzajsy's Avatar
fezzajsy
Default comps
am having trouble fitting the front wheels as they touching the suspension cups
they are 18'' with 215 35 tyres and are et 35...anyone had that sort of problem?how to sort it?
Old Jun 23, 2009 | 04:24 PM
KSA-Cossie's Avatar
KSA-Cossie
3mm spacer or tap the cups with a big hammer.
Old Jun 23, 2009 | 04:33 PM
fezzajsy's Avatar
fezzajsy
looks like its HAMMERTIME
cheeRS mate
PS Luv the siggy mate
Old Jun 23, 2009 | 04:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Good luck m8.
Old Jun 23, 2009 | 05:32 PM
Albino Deano's Avatar
Albino Deano
FROZEN WHITE FRS No2676
Hi mate like i said on the phone today the wheels must be wrong offset no way should u be hitting it with a hammer thats gash, mine are the same 1992 saph 4x4 8x 18 et 35 215 35 18 toyos bilstein suspension fit no probs check the pic.
charlie luciano's Avatar
charlie luciano
Fit a set of coilovers and you'll lose that cup that sits on the strut
Luciano
Old Jun 23, 2009 | 05:34 PM
rs-tuner's Avatar
rs-tuner
toyos have a more rounder edge noticed that on the rear of my s2 where other tyres rub toyos dont
Old Jun 23, 2009 | 05:38 PM
Albino Deano
Not that much i have loads of clearance.
Old Jun 23, 2009 | 06:52 PM
fezzajsy's Avatar
fezzajsy
i know what you mean mate.i cant understand why they wont fit..will be looking to get coilovers in the next few weeks..need to start on the bay asap
Old Jun 23, 2009 | 06:59 PM
benporter's Avatar
benporter
konis? they changed the design, early ones dont catch new ones do and need modifying about 5-6 years ago iirc
Old Jun 23, 2009 | 07:19 PM
Escos2483's Avatar
Escos2483
From: guernsey,c.i.. a rip off island , full of drunks
you dont seem to be having much luck lately .... like my brother says ,, i would not hammer the struts because it is rough and you want to do the job properly ... you will find coil overs will give a lot harder ride ... which might not be so good for jersey roads ... your car ,, your call .. seems strange yours dont fit ,, like ben porter says if u have konis looks like they have changed them ... dean has bilsteins.. dont know what to say mate because spacers aint ideal either ... you will sort it .... regards mark
Old Jun 23, 2009 | 07:31 PM
benporter's Avatar
benporter
just cut a bit of and make a neat job of it and it will be fine
Old Jun 23, 2009 | 08:15 PM
Albino Deano
I cant believe what some are u are saying hammer it cut it best i dont buy a car off u lot it will be two cars welded together even Dick Turpin wore a mask!!!!!!!!!!!!!
Old Jun 23, 2009 | 08:19 PM
KSA-Cossie's Avatar
KSA-Cossie
I think the cup is smaller on newer koni's tbh.
Old Jun 23, 2009 | 08:34 PM
fezzajsy's Avatar
fezzajsy
will try n sort it out without bashing anything..i might have to new front shockers...
Old Jun 23, 2009 | 08:58 PM
nice_head's Avatar
nice_head
I had the same problem and just fitted a set of coil overs, job done
Old Jun 24, 2009 | 02:27 PM
MannheimAlex's Avatar
MannheimAlex
had the problem on mine and found out,that some dampers have another desing of the cup. The origlinal ones will rub on the wheel and koni ones gave a lot of clearance.
But as said, you can mod the old ones to make the fit
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
