no spark
Got a problem with my S2. Getting no spark from the coil. Have changed coil, leads,plugs,dizzy cap,rotor arm,battery. Seems like the green wire on the neg side of the coil is'nt doin what it's suppose to correct me if i'm wrong but it should go live with the ignition and then pulse when the engine has started. Mine goes live but no pulse. Please help before i sell it and go back to VAUXHALLS
check the wire all the way through, think it runs along the cross member, mine lost it spark, tried everything, and in the end it was a small break in the green wire from the coil along the front panel where my intercooler had sat and weared it through!
i had this on the wifes years ago and it was the phase sensor in the dizzy that had gone.
to prove it turn on ignition and fit a wire to middle wire out of 3 on sensor and keep dabbing it down to earth with a plug removed so that you see if it sparks. if it does the sensor is u/s.
hth
thanks
oriont
hth
thanks
oriont
if its not a wiring prob i would say dizzy aswell, you cant get the phase sensor seperatley so will have to get a new dizzy(about 150 quid exchange from ford) maybe try to get a s/h one off here or from a good breakers
Cheers fellas think i will get a new dizzy funny thing is i went out to the car and it started first time today and ran perfect
. Its really hard trying to find a fault thats not there
Cheers everyone just fitted my new dizzy and the cars runnin perfect
I'm now the proud ownew of an S2 with no cable tie round the dizzy
and no longer have to drive my dads omega
and no longer have to drive my dads omega Thread
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
