!FASTFORD COVER CAR !THIS MONTHS! ----- Zetec 2.1L 16v
Old Dec 11, 2004 | 10:16 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Default !FASTFORD COVER CAR !THIS MONTHS! ----- Zetec 2.1L 16v
P8 with MTC board running Distributorless Ignition, Air Injectors, ALS, Water Injection. Bosch 803 green injectors. Weber 3bar map sensor.
A few pics of the car
EDITED AS IT IS NOT A 2.1L ANYMORE!!!!
Old Dec 12, 2004 | 04:15 AM
mattbibs's Avatar
mattbibs
looks a beast!!
Old Dec 12, 2004 | 08:28 AM
tonyturbo's Avatar
tonyturbo
looks like its got potential. nice work.
Old Dec 12, 2004 | 09:13 AM
Versus_Creations
Ask me a question!
cheeRS peeps
Old Dec 12, 2004 | 11:04 AM
1900cvh's Avatar
1900cvh
Jano_OddKidd,
very nice mate !!
Old Dec 12, 2004 | 11:12 AM
pau1rs's Avatar
pau1rs
seen in the flesh... very impressive!!!
Old Dec 12, 2004 | 01:12 PM
luke89's Avatar
luke89
Team HOTHOT!
looks tidy
Old Dec 12, 2004 | 01:43 PM
rich p xr2t's Avatar
rich p xr2t
ODDKID Nice work mate
Old Dec 12, 2004 | 01:46 PM
rabmc's Avatar
rabmc
Scary stuff
Old Dec 12, 2004 | 02:01 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Anyclue as to the engine spec? CVH killer i hope
Old Dec 12, 2004 | 02:26 PM
Paddy rst's Avatar
Paddy rst
looking good, keep the pics coming
Old Dec 12, 2004 | 03:20 PM
essexrsturbo's Avatar
essexrsturbo
a couple more pics...........
Old Dec 13, 2004 | 05:44 PM
white cab's Avatar
white cab
im new to passionford but i have spoken to a few of the guys that use it and they said that you could help me out with a few issues.
Basicly i have done a cosworth managment conversion on my rs cab with the hybrid dizzy but i want to retain the original rst one and just bolt a phase sensor onto the cam cover and put the trigger whell on the pully but i dont know the correct positioning of the 2 phase sensor teeth in comparisson to tdc any ideas as if i can set this up it would then be a bit easier if i wanted to change over to a dis install with a fully blown zetec install
Any help would be appriciated
Old Dec 13, 2004 | 06:04 PM
PhilM's Avatar
PhilM
Whitecab, where in cardiff are you? Im jus out by the airport
Old Dec 13, 2004 | 06:48 PM
white cab's Avatar
white cab
my car lives in cadiff by Roath park but i live in pontypridd are you from rhoose air port then or down that way?
i will post some pics when i get a chance of the car as i have stripped the front end ready for a respray.
thaks for the link to the topic but i cant find the actual distace the sensor pickups are away from tdc are they 90 degrees away from each other and 45 away from tdc?
Old Dec 13, 2004 | 07:43 PM
PhilM's Avatar
PhilM
Aye am down by the airport, Cowbridge infact.
Old Dec 13, 2004 | 08:31 PM
white cab's Avatar
white cab
my mrs is down there shes a student nurse and we only live up the road.
tell you what i like that manifold i saw a similar one on ian howells focus its different.
what did you do with the cps did you locate it in the head on the actual cam and put new pegs in or did you do it off the belt pully?
do you run the two ign amps on a p8 ecu is it possible to run dis off an l6 ecu i have never understood how you can do it i have heard they put a pectel board in there is this there to tell which half of the coil pack to fire as i have seen a conversion on a series 1 where they use a l8 ecu and they use a board which they designed connected to the two ignition amps if i could get the board i think i might go for the dis type ignition myself. i spent a couple of weeks on the 22b bulletin board where they couldnt tell much about it all that happend is my brains started dribbling out of my ears because they were getting to technical straight over my head
Old Dec 13, 2004 | 08:33 PM
PhilM's Avatar
PhilM
I runa SECS S8 ecu bud.
Jano will be able to tell you about how to work a CPS on it!
Old Dec 13, 2004 | 08:54 PM
mitchrs's Avatar
mitchrs
ODDKID that looks sick!!
em... got me thinkin now!!
how much does it owe ya?? if u dnt mind me askin?!
cheeRS
Old Dec 15, 2004 | 04:35 PM
RS220Turbo's Avatar
RS220Turbo
I saw this car at Ace Cafe on Monday, n what a beast, Love the Anti Lag. Nice one Jano
Old Dec 15, 2004 | 07:24 PM
white cab's Avatar
white cab
why is the bonnet slanted on your car oddkid? is it to release extra hot air?
cheers
Old Dec 16, 2004 | 09:31 PM
Disqaulifed driver's Avatar
Disqaulifed driver
From: Somewhere, Drives: the mk3 look its there>>>>>>>>>>>>> Eats:t
that looks like a beast
Old Dec 16, 2004 | 09:56 PM
mitchrs's Avatar
mitchrs
think i saw this the other nite at essex meetin, anti lag is quite mental!!!!
Old Dec 18, 2004 | 09:13 AM
Versus_Creations
Ask me a question!
Yes mate you would of seen the car at the ESSEX RS meeting. It also won CAR OF THE NIGHT
Thanks for the kind words everyone
(Almost everyone )
Old Dec 18, 2004 | 09:22 AM
Versus_Creations
Ask me a question!
Old Dec 18, 2004 | 03:10 PM
white cab's Avatar
white cab
good job new here and hijacked your thread and sorry yes it looks amesome nice work how does the zetec perform compared to the cvh?
Old Dec 18, 2004 | 03:20 PM
white cab's Avatar
white cab
wont happen again just noticed what a fab job you have been doing on the cossie conversions and saw your thread and jumped the gun a bit.
Old Dec 24, 2004 | 04:10 PM
Rossco's Avatar
Rossco
What do you think of the Turbo Displays unit Jano?
Old Dec 24, 2004 | 06:01 PM
murfs frst's Avatar
murfs frst
how much does anti lag cost on a frst,and does it shorten the life of your engine
saw your black xr3i at ace cafe a wile ago and it sounded the nuts
Old Dec 27, 2004 | 11:23 AM
Rossco's Avatar
Rossco
Shortens the life of the turbo, unless you have a maram shaft.
Old Feb 22, 2005 | 09:09 AM
Versus_Creations
Ask me a question!
A couple of videos for ya
www.radley.plus.com/antilag.MOV
www.radley.plus.com/antilag2.MOV
Old Mar 11, 2005 | 09:17 AM
Versus_Creations
Ask me a question!
Old Mar 13, 2005 | 01:47 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Old Mar 13, 2005 | 10:41 AM
Rossco's Avatar
Rossco
Jano wont say anything, dont know why he always posts stuff he is working on, then a few people ask some questions and he dont say a word????
Old Mar 14, 2005 | 01:13 PM
zetec-turbo's Avatar
zetec-turbo
Spec so far (more to come) -
2.0ltr Focus WRC CGI block, 16v zetec head, Ford Motorsport 909 steel rods, Mahle WRC M/Sport Pistons, Dual Bearing Turbo, GRS, Bosch 803's (Greens), 3 Bar, P8 Dizzyless Management, Anti Lag, Water Injection, RS2000 MTX75 Box, three piece shaft, S1 Anti roll bar with S/S adjustable tie bars, Wilwood 4 pots and 4x4 rears........
there is more but thats off the top of my head
Old Mar 15, 2005 | 10:56 AM
Rossco's Avatar
Rossco
Nice!!! Any power figures yet?
Old Mar 17, 2005 | 09:32 PM
Tim's Avatar
Tim
looks good ,
when mines done ill aye a blast with ya down the pod
Old Mar 27, 2005 | 02:09 PM
Versus_Creations
Ask me a question!
This car is not the average RST you have raced mate.
If you want to compete against this car you can on the way to IBIZA with the www.extremerallies.com event
It hasnt had all the R&D spent on it to be thrashed up a drag strip......It can.... and will very well tho look out for the feature soon.....
Old Mar 27, 2005 | 02:57 PM
Charlie Chalk
Unknown.
looks good ,
I will too
Old Mar 28, 2005 | 06:35 PM
tenpotturbo's Avatar
tenpotturbo
scared of a challenge on the strip jano
