wastegate
Hi all can anyone tell me if all cosworth's with a t3 came with a wastegate spring pressure of 5psi at which it opens at.
so basically running a vac pipe from wastegate directly to compressor housing would result in 5psi max boost.
cheers
Yan
cheers
Yan
ive done a little research and apparrently a -31 wastegate wound fully out (lengthening it) would achieve 5psi max psi and no more.
what i dont understand is how much fully out do i turn it out?
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
Aug 14, 2015 07:29 AM
