afr readings?
hi,have fitted innovate lc1 with a gauge,but bit confused to what sort of numbers i should see and when,cars 4x4 saph cossie msd closed loop on greens t34,on idle emmisions should be 0.9% but whats that on the afr gauge?gauge goes from 7.4 to 22.1,booting it it goes to about 10.8,at idle its 13 something,and idling really nice and going well,when it was about 14 odds didnt idle well at all,any help much appreciated thanks col93saphcos
so do i just make it leaner on the ecu screw?or more boost?
on idle about what number would be .9%?
when had it leaner last night didnt idle well at all,although i am waiting on new spark plugs,thanks col93saphcos
i'll phone them on monday,just heated her up,disconnected iscv and lambda sensor and set idle just above 900rpm and gauge to 14.7/.8 was at 12.2 and is idling fine,when lambda was connected adjusting the mix didnt seem to do that much wanted to stay about the 14's,i'll go for a blast and see what like,col93saphcos
your best off talking to stu as he will know what idle strategy he has given you pal,
your best off ringing him and giving him your chip id number,
one thing is for sure though, at cruise in closed loop, you should be around 14.7, the figure will wonder off slightly, but will stick around that fig if your car is going into closed loop correctly.
you will find off the shelf chips are mapped to be safe, so being rich on full boost may be completly normal, as heading closer to peak power could be quite dangerous without the correct monitoring equipment.
yes wil do,i'll give her a run if doesnt seem right i'll put it back to where it was,but think i have managed to lean it of a bit,will see,thanks col93saphcos
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
