Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
Zetec Turbo Pistons & Rods + Turbo +........
Old Jun 19, 2009 | 10:28 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Default Zetec Turbo Pistons & Rods + Turbo +........
pistons and rods - SOLD
turbo dynamics t3 hybrid turbo. never used if myself, but there is play in the shaft so needs refurbing. £100??
Esocrt turbo manifold, there were two small hairline cracks, which i had checked out and they were not a concern, but i told the guy i wanted them welded up anyway, so he did.... £20
Ive also got a brand new ebay turbo t40e or sumut like that..... £100
Also got an internal wastegate housing and an unknwon actuator £100?? for this kit
Green filters air filter, whcih will fit on any of ya 1.1, 1.3 hcs engines. no mini breather filters tho they are lost somewhere.... £10
Old Jun 20, 2009 | 05:41 AM
jonny s2's Avatar
jonny s2
hi mate wot size are the pistons also do they come with rings. are this set 4 silver or black top engines? cheers
Old Jun 20, 2009 | 07:41 PM
slammedorion's Avatar
slammedorion
Also interested in the spec of the pistons....
Are they for a 2 litre, if so what C/R
Also, are they standard fit, or oversized by 0.25, 0.50 ???
You got the rings for the pistons ???
Depending on what spec they are, could well be interested in the for my 2 litre zetec turbo build
Old Jun 22, 2009 | 06:35 AM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Balcktop, but pretty sure a blacktop piston and rods set will work fine in a silvertop. But has to be a blacktop set, and not just the rods or just the pistons.
2.0L
bore size 84.99mm
they are designed to lower the cr to 9.0:1
Complete with ring set also
Old Jun 22, 2009 | 05:22 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
manifold and turbos and Lenso alloys now on ebay, few more items aswell......
http://shop.ebay.co.uk/merchant/1.8esc
Old Jun 23, 2009 | 01:55 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
Pistons and rods sold
mgtkr1
107
Dec 6, 2016 04:23 PM
James Porter
Oct 28, 2015 12:17 PM
Matt Baxter
Sep 16, 2015 08:30 PM
jaimesdna
Aug 25, 2015 06:59 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
