machining down offsets on wheels
Old Jun 16, 2009 | 11:15 PM
RSCossieGaz's Avatar
RSCossieGaz
Default machining down offsets on wheels
continplating maybe getting my wheels machined down to correct offset say et35 so they would fit my car properly,has anyone done this? if so what results did you get?
Can anyone recomend any places to try? baring in mind im in london area! and what sort of cost would this set me back?
Old Jun 17, 2009 | 06:41 AM
Twellsie's Avatar
Twellsie
you need to have a look at how deep the holes are in relation to the depth of the hub face, you may find that removing 10mm or whatever will leave you with very little shoulder for the wheel nuts to locate on
Old Jun 17, 2009 | 06:48 AM
glensport's Avatar
glensport
The special one....
i just had the same problem, not enough meat on the wheels to take a great deal off, maybe safely get a couple of mm but thats it..... i looked into machining the disc instead as you can safely get another couple of mm out of that which helps as well!
Old Jun 17, 2009 | 08:24 AM
RichieST's Avatar
RichieST
What offset are you starting with mate?
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
