key problem mk6 escort
Old Jun 16, 2009 | 05:37 PM
STU170e's Avatar
STU170e
Default key problem mk6 escort
hi i hope somone can help i have a 1996 escort si and the key has started to become worn and sometimes takes ages to unlock and start the car my question is do i have to replace the ecu if i replace the locks ?
Old Jun 16, 2009 | 06:00 PM
RichieST's Avatar
RichieST
Mrs had the same problem on her mk3 fiesta, the key gets worn out so it doesnt operate the lock any more.
It was only a shitter so I didn't bother having an expensive chip key re-coded or anything, so I just got a cheap key cut, cut the old metal shaft bit off the old key, and glued the transponder bit to the new key, worked a treat!
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
tankybaby66
Aug 9, 2015 07:13 AM
