Whining noise on boost, what to check apart from knackered turbo?
Old Jun 16, 2009 | 01:53 PM
rog's Avatar
rog
Default Whining noise on boost, what to check apart from knackered turbo?
Ok I have a funny whining noise on boost, I AM AWARE IT COULD BE THE TURBO, but what else could possibly cause this, an air leak, or perhaps even a fuel pressure issue?
Fixed a couple of things the other day and now the car pulls really well only boosting 12-13psi, but i don't want to push it anymore as this is when it starts whining. Turbo was ok before i got the engine rebuilt, is there anyway that leaving it sitting would make it degrade and whine like that???
Old Jun 16, 2009 | 02:21 PM
AlexF's Avatar
AlexF
boost leak possibly.
Old Jun 16, 2009 | 02:25 PM
JokerDisco's Avatar
JokerDisco
As above check your hoses.
I had this problem now and again when it came on boost it would whistle like the turbo was on its way out. Found out the problem was the coupling boost hose that connects the throttle body to the charge carrier needed tighting as it was leaking air. This was on my series 2 not a cossie but I would presume the same applies in both circumstances.
Old Jun 16, 2009 | 02:35 PM
rog's Avatar
rog
Ok cheers, i'll have a look today, i'm also thinking to check the amal valve, how does it work???
Old Jun 16, 2009 | 02:38 PM
bud-weis's Avatar
bud-weis
Football Cwazy
i'd be very surprised if its the amal valve, it's basically just an electronic bleed valve.
I think it'll be your boost hoses, remove and refit all 3 and im sure it'll be pukka!
Old Jun 16, 2009 | 02:46 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
check your vacume hoses too, it might sound funny but this happend o my m8's 3 door and he found out it was his alternator bearings
Matt Baxter
Sep 16, 2015 08:30 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Churtz
15
Aug 13, 2015 06:40 PM
Bezzy41
Aug 3, 2015 10:31 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
