spark but no injectors
Old Jun 15, 2009 | 08:33 PM
mark r's Avatar
mark r
Default spark but no injectors
can anyboy tell me what tells the ecu to give power to the injectors as cant get car started.have fuel have spark but have no power to injectors.have connected a led to injector plug to see if there getting power,every now an then the led would flash but its not constant as it should be
cheers mark
Old Jun 15, 2009 | 08:34 PM
Icurus's Avatar
Icurus
What car is this for?
Old Jun 15, 2009 | 08:38 PM
S1's Avatar
S1
Check the all the earths in the engine bay, my frst wouldnt start after a 4 year rebuild. was an earth on the drivers side inner wing. All the pumps primed, plugs fired, just injectors wouldnt work.
Old Jun 15, 2009 | 08:39 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
cheers mark
gessing form the information you have given. but its normaly the cps that firs the injectors and the spark but if you are getting a spark but no injectors then you have a problem
Old Jun 15, 2009 | 09:04 PM
mark r's Avatar
mark r
its a 3dr cos
Old Jun 15, 2009 | 09:06 PM
bad boy rs's Avatar
bad boy rs
crank sensor
Old Jun 15, 2009 | 09:07 PM
mark r's Avatar
mark r
its a 3dr cos,just done a build up,car was running,parke it in garage overnight went next day to start it and it wou'lt start.if cps(tdc) does spark then what does phase sensor control?
Old Jun 15, 2009 | 09:13 PM
focusv8's Avatar
focusv8
Phase sensor = Spark
Crank sensor = Injectors
Or it might be the other way round?
Old Jun 15, 2009 | 10:44 PM
mark r's Avatar
mark r
does anybody know for sure which i.e. phase or cps sensor controls injectors so i know which to try first
Old Jun 15, 2009 | 11:05 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I was under the impression that on the L1 ECU loom the "power" feed for the injectors came from the fuel pump relay and then the injectors are switched to earth by the ECU in order for them to fire.......
Might be worth looking for your 12 volts and work from there........
Old Jun 15, 2009 | 11:06 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Infact, looking at wiring diagrams, all the cossie wiring looms are like this - 12 volt feed from the fuel pump relay once the ignition is on......
Old Jun 16, 2009 | 09:00 AM
As said^^ 12v for the injectors will be constant when turned on, so check it's there first, it does normally come from where said.
Old Jun 16, 2009 | 10:19 PM
mark r's Avatar
mark r
when you first click the ignition on the led i put in injector socket lights up but then it goes off ,so you say the best place to check is the fuel pump relay.
can you tell me where i can find such relay?
could this also be a bad earth?
as the fuel pump is priming?
ive ordered a new tdc/phase sensor today from matt lewis so when they get here im gonna whack them on gap them properly and see how it goes.
Old Jun 17, 2009 | 05:49 PM
mark r's Avatar
mark r
bump
Old Jun 17, 2009 | 05:58 PM
nellyscossy's Avatar
nellyscossy
here we are
try this, i use this info all the time very useful
http://www.cannell.co.uk/Ford_Worksh...sis%20Info.pdf
Old Jun 19, 2009 | 07:36 PM
mark r's Avatar
mark r
i now have injectors after changing relay but car still wont start .anymore ideas anyone?
HELP
Old Jun 19, 2009 | 07:38 PM
mark r's Avatar
mark r
Originally Posted by nellyscossy
here we are
cheers nelly i used this to check all the wiring. was great info!!!!
Old Jun 20, 2009 | 03:06 PM
hughy's Avatar
hughy
this sounds like the same problem i have can not get ecos started turning over alright but wont fire up...have you had the car started since rebuild mate? im just pissed off at this stage tried and checked everything, hope you get her started, cheers hugh
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
