Floor fitters?
Old Jun 14, 2009 | 05:21 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default Floor fitters?
We are going to be fitting laminate flooring to our hallway but not sure how to work out sq metres.
The hallway is 3.5ft wide and 24ft long can anybody translate that in to sq metres,obviously we will need a bit extra for mistakes etc
cheers
Old Jun 14, 2009 | 05:26 PM
Red16's Avatar
Red16
3.5ft is 1.07m
24ft is 7.3m
so around 8 square metres
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
cheers
25.60 M2
plus 10% for waste/cuts
gives you 28.16 M2
So buy 30 M2 and you will be fine.
(ps: you cant really write 3.5ft as an imperial measurement, should be 3'6")
I take it you have thought about this, but if its possible lay it with the skirting removed.
Leave about a 1/4" gap for expansion (about 10mm) and relay skirting.
Theres nothing worse than seeing laminate with those horrid corner edgine strips on the skirting!
Also try and do a 3 stage stagger, to give a bit better detail. This is the mistake most DIYers make buy just laying it in strips.
Old Jun 14, 2009 | 05:27 PM
Lee Reynolds's Avatar
Lee Reynolds
Instead of measuring it in feet then converting it, why not measure it in metres?
Old Jun 14, 2009 | 05:29 PM
Dicko&Vacant
because my old man measured it lol
cheers
Lee Reynolds
Originally Posted by Lee Ivatt
25.60 M2
gives you 28.16 M2
7.8 sq m im glad your not pricing for me Lee
Old Jun 14, 2009 | 05:31 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
why didnt you just measure it in metres in the first place? its on the other edge of the tape measure.
***edit to say ive seen your above reply***
Old Jun 14, 2009 | 05:35 PM
Dicko&Vacant
so what one do i need lol lee ivatt's or lee reynolds measurements
One sounds like it wont be to expensive other sound extortionate
Old Jun 14, 2009 | 05:36 PM
Lee Reynolds
Mr Ivatt is still suffering with smoke inhilation lol
Old Jun 14, 2009 | 05:37 PM
fuzzy's Avatar
fuzzy
24 feet is roughly 8 metres ans 3.5 feet is about 1 metre so id go for 8x1 and 8 square metres.
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
doh, im hungover, 25.60 is the linear conversion of 84 feet, not squared
Yeh get 10m2 youl be fine.
Old Jun 14, 2009 | 05:39 PM
Dicko&Vacant
no wonder hes got a flash place and numerous cars he must rob people blind
Old Jun 14, 2009 | 05:40 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Originally Posted by Red16
3.5ft is 1.07m
24ft is 7.3m
thats was some quick editing if ever i did see some, i believe your original answer was around 25 also
Old Jun 14, 2009 | 05:42 PM
Lee Reynolds
Easy mistake
Old Jun 14, 2009 | 05:44 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Over ordering is how I get to have a nice house with all the bits done
Old Jun 14, 2009 | 05:46 PM
Red16's Avatar
Red16
yeah i put 25 sq metres (worked out by 3.5' being roughly 1m, then multiplied by 24ft giving 25 sq metres... what the fucks that all about )
then edited it to say "ignore that i read it wrong", then worked it out properly and edited it again whats your excuse?
Old Jun 14, 2009 | 05:49 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
yeh you did the same as me almost, tho thats not even a linear measurement your way
Im hungover, and would have measured it in metric to start with
Old Jun 14, 2009 | 05:52 PM
Red16's Avatar
Red16
True... but 1m is a little smaller than 3 1/2ft hence the 25sq m instead of 24sq m either way it was still a schoolboy error
Old Jun 14, 2009 | 05:55 PM
Lee Reynolds
Still costs the same though
Old Jun 14, 2009 | 05:57 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
not when the customer pays for it
Old Jun 14, 2009 | 06:03 PM
Dicko&Vacant
might be a daft question but a joiner we had in doing some work said we could use our existing carpet underlay for the laminate
Its an expensive carpet with decent underlay just wanted to ask first.
Old Jun 14, 2009 | 06:45 PM
mrjenrst's Avatar
mrjenrst
no you cant use carpet underlay at all, fucking chipies know fuck all about floors, FACT!. floor area is 7.8m2 but allow alot more
Old Jun 14, 2009 | 06:50 PM
Twellsie's Avatar
Twellsie
25.60 M2
gives you 28.16 M2
yeah you can, 3.5ft is English, 3'6" is imperial
Old Jun 14, 2009 | 07:45 PM
Lee Reynolds
So you DO rip them off then
Old Jun 14, 2009 | 07:46 PM
Lee Reynolds
Lol not this old chestnut
NO NO you cant use carpet underlay!
Old Jun 14, 2009 | 07:47 PM
Dicko&Vacant
how else did he get a fancy pizza shed
So do i need a special sort of underlay or is it all the same stuff?
Old Jun 14, 2009 | 07:54 PM
fuzzy's Avatar
fuzzy
floor layers are the guys that couldnt make it as chippies....fact. in the old days floor layers would have been the village idiot.
Old Jun 14, 2009 | 08:08 PM
rog24's Avatar
rog24
Default laminate flooring
i always use foam under laminate flooring if that helps. roger
Old Jun 14, 2009 | 08:10 PM
mrjenrst's Avatar
mrjenrst
Nah its cos they didnt want the pay cut
Old Jun 14, 2009 | 08:12 PM
mrjenrst's Avatar
mrjenrst
the underlay depends on the sub floor, there are different ones too many tbh but a bit more info and could advise better
Old Jun 14, 2009 | 09:35 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
them and the sparks
Old Jun 14, 2009 | 10:38 PM
mrjenrst's Avatar
mrjenrst
What do ya mean the old days? nice edit btw
Old Jun 14, 2009 | 10:39 PM
mrjenrst's Avatar
mrjenrst
and the sparks
True
155lee
Sep 6, 2016 11:10 AM
Orion_Gav
Sep 29, 2015 04:50 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bassboy
Sep 10, 2015 08:54 PM
