anyone taken an rb26 lump out ?
just wondering easiest way to get it out. sump defo wont come off with engine in there. is it easiest to drop it out the bottom on the subframe with gearbox still on ??
jesus im guessing youve found the problem then mate?]
internal im guessin
al the ones ive seen get dragged through the front if that helps lol
internal im guessin
Best way to do it is drop it complete with the box from the bottom and refit the same way.
Horrible job to be honest as the turbo's are in a very difficult position as is all the silly pipe work/connections to the inlet.
Take your time and its not to bad if your dropping it complete.
