what can make a knock sensor show knock ?
Old Jun 13, 2009 | 07:36 AM
scoooby slayer's Avatar
scoooby slayer
Default what can make a knock sensor show knock ?
i dont really understand im assuming a knock sensor sees engine vibrations ? what engine symptoms would make a knock sensor give out excessive readings, can any engine excessive vibration make it show readings ?
Old Jun 13, 2009 | 07:54 AM
Stu @ M Developments's Avatar
PassionFords Creator
Knock can be caused by a lot of things, most common being:
Bad Fuel
Wrong plug grade
incorrect mixture (lean or rich)
head gasket failing
valve guides failing
piston rings worn
Incorrect detection can be caused by lost of things too, such as:
loose engine parts
worn valve train
bore wear
bearing wear
The list goes on...
Old Jun 13, 2009 | 07:55 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
exactly that mate. The knock occurs when the piston rattles it's way down the bore thus creating a vibration. This is what the sensor detects.
One thing worth doing is to replace the sensor and tighten the bolt down to the correct torque. Some sensors rely on a certain amount of 'crush' to read correctly. Incorrect torque can result in iffy readings. Once overtightened the sensor should be renewed.
Old Jun 13, 2009 | 07:59 AM
scoooby slayer
Bad Fuel
Wrong plug grade
head gasket failing
piston rings worn
loose engine parts
worn valve train
bore wear
bearing wear
The list goes on...
thanks stu confirmed my thoughts mate. im gonna take a vid of the noise of my engine today if i can get it to do it. its so quiet and disapears after a second ?
Old Jun 13, 2009 | 08:35 AM
Ebonycossie4x4's Avatar
Ebonycossie4x4
as i said before youre a brave man buying a skyline with a rattle.
All the best mate, i hope it wont be to expensive.
Old Jun 13, 2009 | 09:23 AM
fordsportjay's Avatar
fordsportjay
+1
Old Jun 13, 2009 | 09:28 AM
AlexF's Avatar
AlexF
yup defo brave
Old Jun 13, 2009 | 09:43 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
or.....
Old Jun 13, 2009 | 10:13 AM
scoooby slayer
Originally Posted by JTECHSAFF
or.....
wont be crying mate. i cant loose can get another very low miles lump for Ł2800
Old Jun 13, 2009 | 10:14 AM
JTECH James
Passion for Fords!
yeah i saw that,
not a bad option if its fubar
Old Jun 13, 2009 | 10:20 AM
scoooby slayer
yeah i saw that,
id be interested in your input mate. il post a vid of engine noise latter once its done.
Old Jun 13, 2009 | 10:23 AM
JTECH James
Passion for Fords!
no probs i will have a listen later
adam151082
Aug 30, 2015 08:34 AM
rdvil
Aug 15, 2015 12:11 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
