help needed on plugleads
Old Jun 12, 2009 | 09:27 PM
andy130's Avatar
andy130
Default help needed on plugleads
which lead goes where on the dizzy cap, its 2wd dizzycap, any help be great thanks, andy
Old Jun 13, 2009 | 10:21 AM
From engine to inner wing it reads 4-2-/coil lead/-1-3,.
Old Jun 13, 2009 | 11:17 AM
andy130's Avatar
andy130
hi, so its 4-2 the top row plus coil lead and 1-3 bottom row? cheers
Old Jun 13, 2009 | 01:01 PM
I can't remember which is top/bottom etc, but so long as when you look down at it from above it is numbered that way going from engine to nearside inner wing it is fine, I don't use a dizzy cap anymore.
Old Jun 13, 2009 | 02:18 PM
Stu @ M Developments's Avatar
PassionFords Creator
If you are looking down on the cap with the connections away from you.
top two are 4 - 3
bottom two are 2 - 1
Middle is coil.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
