3 door won't start!
Old Jun 12, 2009 | 06:38 PM
mr_intex's Avatar
mr_intex
Exclamation 3 door won't start!
i have replaced the cams, tappets, gaskets, cam bearings, all belts, spark plugs, cam pulleys, i think that's it!
i have timed up the engine all markers are exact including the distributor.
i numbered the ignition leads before i took it apart and replaced them back.
i turned the engine round with the spark plugs in and the spark leads off for 20 seconds.
have i just flooded it?
any ideas?
thanks
Old Jun 12, 2009 | 06:52 PM
Icurus's Avatar
Icurus
You might well have done.
Why did you do that? where you trying to build up oil pressure? If so, next time dis-connect the injectors too
Old Jun 12, 2009 | 06:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
is there deffo fuel coming out?
remove and plug and it will be wet if you have flooded it
if thats the case, remove all plugs and leave it for a bit
if no fuel the cut off might have tripped?
Old Jun 12, 2009 | 07:01 PM
Adam R4's Avatar
Adam R4
British Rally Snapper
Have you done the wiring youself? if so have you wired the crank sensor the right way round?
Old Jun 12, 2009 | 07:10 PM
mr_intex's Avatar
mr_intex
the crank sensor has not been replaced.
the auxilary pulley was out by three teeth so i obviously put it back to the correct timing position.
thanks for all your help!
Old Jun 12, 2009 | 07:23 PM
Did you check the rotor arm/phase alignment was correct after the belt change, as you turned the dizzy/aux shaft.
Old Jun 12, 2009 | 07:27 PM
mr_intex's Avatar
mr_intex
according to the manual, the distributor arm lines up to the side of the distributor body perfect.
thanks
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
