2.0 zetec bike carbs
Old Jun 11, 2009 | 07:46 PM
godrikki's Avatar
godrikki
Default 2.0 zetec bike carbs
been offered bike carbs for my car but how easy is the conversion i obviously know i need an inlet made up but do i need management to run them or do i just need them set up any help much appreciated
Old Jun 11, 2009 | 08:00 PM
Mark V8's Avatar
Mark V8
You would be better off with bike bodies and injection, you are going to need management to run the ignition anyway so you might as well do the job properly
Mark
Old Jun 11, 2009 | 08:19 PM
godrikki's Avatar
godrikki
so you reckon i would be better off with throttle bodies rather than carbs but either way im going to need management
Old Jun 12, 2009 | 09:39 AM
With carbs you won't need management, but with throttle bodies you will, if fitting carbs you will need to sort the ignition side of things, if going tb's might as wll just use a ecu that does it all anyway.
As said tb's so much better driveability generally than carbs.
mk3ste
Oct 17, 2021 10:09 AM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
