Revs to 2500 then cuts out?
Old Jun 11, 2009 | 05:00 PM
Asturias's Avatar
Asturias
Default Revs to 2500 then cuts out?
My 91 4x4 cossie starts fine and idles fine but when you rev it to just over 2k revs the rev needle drops it backfires and engine cuts out?
Just changed the ect sensor but still the same!
Cheers for any help.
Old Jun 11, 2009 | 05:03 PM
LHD220Turbo's Avatar
LHD220Turbo
check the crank poistion sensor (CPS); give it the "wiggle" test, also check the crank pulley to make sure that is all in order; (notches in place etc)
timsrs
Nov 13, 2018 11:48 AM
TPM961
Jan 15, 2018 10:50 AM
Mark RS
Oct 12, 2015 06:01 AM
Fudgey
21
Sep 30, 2015 06:19 PM
