Fiesta turbo 325mm Brakes
Old Jun 10, 2009 | 07:53 PM
rsdan123's Avatar
rsdan123
Default Fiesta turbo 325mm Brakes
Hi, anyone put the hi spec 325mm brake kit behind 16" compMOs with out any mods
Danny
Old Jun 10, 2009 | 11:26 PM
rsdan123's Avatar
rsdan123
anyone?.... rang up hi-spec there is a women that answers and she dont know the difference between her left and right!
Danny
Old Jun 10, 2009 | 11:30 PM
burnzy's Avatar
burnzy
burnzy
well i'v heard you can squeeze some 300's under 15's but i very much doubt you'll get 325 under 16's unless shaving off some of the caliper to lower the profile but i could be wrong, but atleast it's a start,
don't they have a technical dept at hi spec or summit that the daft bint can put you through too
Old Jun 11, 2009 | 09:38 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Don't know what Hi-Spec are like for clearance, but my 330's with Brembo's fit behind my 16's, although I wouldn't do it again. The wheels are damaged as a result of them being so close.
Old Jun 11, 2009 | 10:17 AM
Micky's Avatar
Micky
For God's sake dont use Lo-Spec rubbish.Use either Compbrake or AP.They have a useless customer relations department (as you've already half found out) and take ages to deliver the goods after you've paid for them,plus 50% of the time the brakes don't fit anyhow!!!! Do a search of them and read all the bad reports.Regards,Micky
Old Jun 11, 2009 | 11:14 AM
It's a shame but true the service stinks often which is a pity as they can turn out some really good stuff that works.
I've known geoff for around 15 years, and he is certainly capable of good work, but comments about service are true in my experience.
If you still want to chat to him, pm me and I'll give you his home number.
Old Jun 11, 2009 | 11:37 AM
Oranoco's Avatar
Oranoco
I would say it will depend on the brakes and on your wheel choice. I know my 285mm brakes were very tight on 15's and there wasn't much clearance with a 300mm ST170 conversion on 16's.
Old Jun 11, 2009 | 03:28 PM
Seademon's Avatar
Seademon
Last time I went in Hi Spec that woman had post it notes stuck to her cardigan so she wouldnt forget stuff..
Old Jun 11, 2009 | 03:59 PM
xrsi's Avatar
xrsi
ive found hi-spec very helpful when getting spare bits from them for a set of their brakes i had on a car i broke and then used some of the bits on my own...
i seperatly ordered a couple of times and they have always been with me in a couple of days, i was told a wrong price and got charged more for a set of rebuild kits but they refunded me the difference in what i was charged and quoted no questions asked although they did put on the refund invoice next time you will be charged x amount for a rebuild kit :s
thing i have found with the billet 4-pots is they use random pads....
talking of which anyone have any idea what ferodo pad fits the billet 4 pot 300mm kit?
Old Jun 11, 2009 | 04:10 PM
lee.boy's Avatar
lee.boy
here's 300mm behind 16" comps perfect fit but think 325mm will be to much behind 16".
Old Jun 11, 2009 | 04:50 PM
I know geoff based a lot on volvo shape pads, long time ago mind.
Old Jun 11, 2009 | 05:29 PM
rsdan123's Avatar
rsdan123
cheers for all your advise guys.
Christian: what brembos was you using? focus RS ones? also have you any idea what offset bells you used?
Old Jun 11, 2009 | 06:04 PM
NUTS RuS's Avatar
NUTS RuS
Christians hub is an Escort - yours is a Fiesta, dont try and copy his offsets Danny
JoeyBoyden
Jan 4, 2024 02:36 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Aug 10, 2015 12:08 PM
Bosch
Aug 4, 2015 05:14 PM
