trouble with stage 3 and perhaps msd eprom
Old Jun 10, 2009 | 07:38 PM
florent78's Avatar
florent78
Default trouble with stage 3 and perhaps msd eprom
hi
I've got a sierra 2WD with some modifications :
L8
lambda sensor
knock sensor
BD10 (inlet + exhaust)
swedish plenum
RS500
mongoose
T35 + 0.48
siemens 55 injectors and everything required (map waste gate ....)
new water sensor (true magneti marelli)
thermostat 82
fuel pressure 3.5
I ask msd an eprom with the close loop
the first time, I do as required 5 turn right and 1,5 left
it was really bad, car was really too rich
and plug where "dead" after 40 km ; unable to start the car, plugs dark dark
the max value for the exhaust temp (my egt is fitted on the turbo A/R 3cm after the end of the exhaust manifold
was 720 °C with is really low
I ask msd and he tell me to do 1 more turn left to lean the car (the CO value at 4000 rpm should be between 2,5 and 5)
4000 rpm = out of the close loop range
first I do 0,5 ; car sames a little better and max exhaust temp is 810 °C
I'm been to a garage doing a check with the CO (before I do the 0,5 turn left, so I have 1 turn as required with msd)
results :
CO at idle is arround 3,5-4 (I have the close loop)
CO at 4000 rpm is 7,5 (with is more than 2,5-5)
and the gas temp at idle is arround 330°C (normally should be arround 450)
I ask again msd, but to be honnest the person answer really shortly (2 sentences) and he just tell to check with the afr (for sure but it's the price of the eprom)
2 friends of me tell me the had problem with the 82°C thermostat and put back the 88
I will do this to check, but I really doubt of the results
can someone help me
any idea ??
would be nice if someone can give me with an L8 and close loop
the CO value at idle
gas temp at idle
thanks
Old Jun 10, 2009 | 07:43 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
co on closed loop is normally around 0.90%
it is vital all base settings are correct like fuel pressure etc, and that there are no air leaks
is it deffo going into closed loop? have you tried a muliti meter at the ecu terminals to check the lambda sensor is working corectly?
Old Jun 10, 2009 | 08:40 PM
silky16v's Avatar
silky16v
Get on That!
have you fitted a PF09 TPS (4x4) or do you have the (2WD) TPS still fitted
as if you fit a L8 on a 2wd loom you need to swap the wires over for this when fitting a PF09 TPS
so you ECU night be seeing full throttle@idle and idle@full throttle
Old Jun 10, 2009 | 09:39 PM
florent78's Avatar
florent78
yes
4WD fitted and wire reversed
fuel pressure ok
and no air leak
regards
florent
Old Jun 11, 2009 | 10:20 AM
If the thermostat is at all suspect just change it anyway, I always use 88C.
Old Jun 11, 2009 | 11:22 AM
florent78's Avatar
florent78
it's a brand new 82°C
but 2 friend had problem with the 82
any idea for the CO at 4000 rpm ???
thanks
Old Jun 11, 2009 | 04:32 PM
I had no end of grief with 82C stats of various makes, so now use WAHLE, it's the only one that worked perfect and stayed working.
Old Jun 11, 2009 | 08:48 PM
Thanasis's Avatar
Thanasis
thanks
what problem they had with the 82 mate?
Old Jun 11, 2009 | 11:39 PM
florent78's Avatar
florent78
1 friend had engine power problems
with the 82 --> dyno = 327
with the 88 --> dyno = 380 (with is normal with the car configuration)
the second had problems with the rev, with the 82, the car "cut" arround 4000 and more
after with the 88 .. no problem
to be honnest I do not understand why a simple thermostat can change something
but I prefer to be sure and remove 1 doubt so I change it
Old Jun 12, 2009 | 08:44 AM
The most influential factor for CO/fuelling is the temperature, other things offer a trimming of this, but CTS is most deciding factor by a long way, maybe yours for some reason is/was running far too rich ?
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
