coilovers n rebound....
Old Jun 9, 2009 | 09:32 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Default coilovers n rebound....
really dont like my set up...front to hard....will softening the front spring rate help with the rebound/bump rate on my gaz coilovers....or are they just as they are reguardless of spring rate...????......help.......
Old Jun 9, 2009 | 10:08 PM
Char1ie's Avatar
Char1ie
Bump and rebound is the shock rather than the spring. Should be a big knob on your coilovers to adjust. Turn that all the way one way for full hard. Your car will kangaroo over the bumps. Then turn to full soft to notice the different and progressively move the dial until you have a setting you like.
Charlie
Old Jun 9, 2009 | 10:29 PM
burnzy's Avatar
burnzy
burnzy
Originally Posted by Char1ie
Bump and rebound is the shock rather than the spring. Should be a big knob in the drivers seat that should be able to adjust it. Turn that all the way one way for full hard. Your car will kangaroo over the bumps. Then turn to full soft to notice the different and progressively move the dial until you have a setting you like.
Charlie
thats a bit harsh
sorry childish i no but just had to be done
Old Jun 9, 2009 | 10:47 PM
scoooby slayer's Avatar
scoooby slayer
i put 150 lb springs on the back of mine was perfect then on 18 clicks from soft on adjuster. fronts i left standard springs and middle way on dampening and felt good for me.
Old Jun 10, 2009 | 05:23 AM
pete mcrash
char1ie....just the cheaper coilovers fella, mine only adjust height and stiffness.....as for spring rates.....think mine are 330 (ish) on the front and 180 on the back.....so the front is set on "full soft" (too hard) and i have to stiffen the back up to match the front a bit, other wise it wobbles like fook along the road......i need softer front springs......
Old Jun 10, 2009 | 09:24 AM
I'd be tempted to run a little softer on the front of around 300lb", and around 200lb" for the rear, this is what I run.
I find it really comfy, on front normally only rebound adjusts with knob, rear adjusts bump as well as rebound.
Old Jun 10, 2009 | 09:56 AM
Mike1's Avatar
Mike1
Just out of interest Pete, why did you go to a coilover set-up? Do you do a lot of track days.....or was it the ability to corner weight your car that appealed? Or did you find a conventional spring/shock arrangement too soft?
Old Jun 10, 2009 | 02:53 PM
pete mcrash
.....none of the above..........had AVO adjustables on the car....one of the fronts broke/leaked so i got a set of gaz (£500) coilovers and was advised to get these spring rates.......should of had my AVO's fixed and maybe a better set of springs instead of C/D ones.....he-ho thats life
Old Jun 10, 2009 | 06:37 PM
Mike1's Avatar
Mike1
C/D being Chassis Dynamics ones?
I had those on mine - std height uprated
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
