x reg ford fiesta 1.6 zetec over heating
recently a mate of mine drove across a ring road and it went straight into the red!
just wanderin wat sort of things to check for?
:thermostat
:blockage
is as far as we got,
also he says to me his heaters in the car only blow hot air out, i was reading another post and it said that this could have something to do with it some how?
any ideas on wat else to check while im there would be great!
:thermostat
:blockage
its very likely to be the heater control valve that is at fault, it's under the bonnet just tucked behind the false scuttle panel in the middle, you should see 2 hoses connected to it from the front side of the false panel.
you will have to check on ford's latest revision of this as there are so many versions and some are known to cure the problem and some are not.
think the part no. is relevent and is back to ending in AA again, not AC as per the last revision.
JoeyBoyden
Jan 4, 2024 02:36 PM
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
