l8 ecu experts, pls look, damaged ecu with pics, can it be fixed?
Old Jun 9, 2009 | 09:08 PM
stu21t's Avatar
stu21t
Default l8 ecu experts, pls look, damaged ecu with pics, can it be fixed?
i have a l8 ecu that is still working, car still runs fine, but there is evidence of damage to it.
i think its pins 1, 19 and 10 that are damaged,
1 & 19 are both earths, they obviously still work or it wouldnt run would it?
pin 10 is the ign relay trigger, now heres the fun part,
the relay and therfore ecu doesnt run unless i earth this pin, ecu pin 10 blue wire with yellow tracer. with this connected to earth everything runs ok (i think)
heres some pics of the damage
pins 1 & 19, all charred
the bits in red are the charred pins,
is it still ok to still run the car as is?
can it be tested by any1?
can it be repaired?
Old Jun 10, 2009 | 06:52 AM
stu21t's Avatar
stu21t
bump
Old Jun 10, 2009 | 08:36 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Use macro mode on ya camera mate.......pics will come out clearer! LOL!
Old Jun 10, 2009 | 08:50 AM
stu21t's Avatar
stu21t
Dodgy iPhone pics m8.
Will borrow a proper camera and get decent pics tonight if I can.
Old Jun 10, 2009 | 11:08 AM
stu21t's Avatar
stu21t
No experts here today?
Old Jun 10, 2009 | 11:13 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its blurrry as fuck I dont see how you can expect anyone to comment without seeing it.
You may as well have drawn a picture of your ecu with crayons.
Old Jun 10, 2009 | 11:14 AM
Chip's Avatar
Chip
Ps
Personally I wouldnt bother trusting a repaired 20 year old ecu, i would just put a decent modern one on instead, or at least just buy a secondhand 20 year old one in good order if you must stuck with the L8 for some reason.
Old Jun 10, 2009 | 10:54 PM
cjwood555's Avatar
cjwood555
It looks like they've over-heated (probably due to short or other fault) and have probably damaged the pads/tracks connecting to them. If you know what caused it and have sorted the fault, try scraping off the solder-resist about 1mm either side of the pin with a scalpel and re-flow the solder. You'll need at least a 25W iron and have it nice and hot - at least 300degC, otherwise you'll just lift the tracks clean off on a board that age!
HTH
Chris
Old Jun 11, 2009 | 09:03 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
yes it can be fixed ,you will also need to repair /replace the wiring loom ecu multiplug
typical repair cost is £100 +vat
Old Jun 11, 2009 | 11:39 AM
stu21t's Avatar
stu21t
cool I'll b in touch.
JK12
33
Apr 26, 2021 12:09 PM
Nov 3, 2015 04:08 PM
Porplus12
Sep 10, 2015 07:20 PM
gavt123
Sep 5, 2015 10:03 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
