Metering Head?
Old Jun 9, 2009 | 08:21 PM
GooseRST's Avatar
GooseRST
Default Metering Head?
What would be the symptoms of a bost metering head?
Old Jun 9, 2009 | 10:29 PM
Marts's Avatar
Marts
poor fueling, poor starting, poor running, poor pockets
Old Jun 9, 2009 | 10:34 PM
T28 RST's Avatar
T28 RST
Ok then
Default Big boost
Old Jun 9, 2009 | 10:54 PM
GooseRST's Avatar
GooseRST
well my cart has had the leads, spark plugs new head and head gasket done today... and its still cutting out!
wtf could it be, its not the tps either
Old Jun 10, 2009 | 10:06 AM
GooseRST's Avatar
GooseRST
what else could be causing it to cut out at random intervals...its really starting to bug me now !
Old Jun 10, 2009 | 12:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Whilst under load of when letting off/idling?
Old Jun 10, 2009 | 12:57 PM
GooseRST's Avatar
GooseRST
everything mate: driving it normally, booting it and from idle...
yet sometimes it will go for like 30 mins and not cut out, other times will cut out 3 times in as many minutes?
Old Jun 10, 2009 | 01:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
In that case it's either that your not getting fuel at all (randomly) like if the fuel pumps cutting out (pink realy maybe), or it's an ignition problem like your dizzy, coil, the green wire that runs from the coil to the ECU has a bad connection/break, or king lead etc...
Old Jun 10, 2009 | 01:09 PM
GooseRST's Avatar
GooseRST
thanks mate, are all those easy to fix and what do you think worst case scenario would be?
so its deffo not the metering head?
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
gingeRS
17
Oct 2, 2015 09:42 AM
DAZZER
Sep 30, 2015 08:43 PM
