Bearings, would you change them ? (HEAVY pictures)
Old Jun 5, 2009 | 05:30 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Exclamation Bearings, would you change them ? (HEAVY pictures)
Here are 3 pictures of my main bearings state, would you change them ?
Same with conrods bearings, would you change them ?
There are some small "pitchs" but that's just dust.
I am going for 350+ bhp and don't wanna end up rebuilding the engine. Problem is I've already weight matched the rods/pistons, so changing the bearings would mean I have to re-weight all again. Ok if it can save a full rebuild I will change everything, but don't wanna change something which would be useless to change.
Advices welcome !
Old Jun 5, 2009 | 05:40 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Without ANY shadow of doubt.
You should have seen the ones I threw away recently, they looked LOADS better than that.
Old Jun 5, 2009 | 05:50 PM
BigErn's Avatar
BigErn
Every time I take an engine apart they get changed. Not worth risking re-using them for the cost of new ones. The price of a set of bearings could save you the price of an engine rebuild.
Old Jun 5, 2009 | 05:53 PM
OldDan's Avatar
OldDan
For the price - YES.
Old Jun 5, 2009 | 05:57 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Ok lads, I will change everything then. I wasn't sure if it was really needed, but yes, considering the cost of a full engine rebuild after a bearing failure, its not worth the risk !
Thanks !
Old Jun 5, 2009 | 06:02 PM
chameleon's Avatar
chameleon
look fooked to me.........hope you have looked at the crank aswell.......
Old Jun 5, 2009 | 06:17 PM
LHD220Turbo's Avatar
LHD220Turbo
while its apart i would ALWAYS change them as a matter of course.
they are pretty cheap considering how vital they are
Old Jun 5, 2009 | 06:21 PM
chameleon's Avatar
chameleon
make sure you clean all that rust off too..........
Old Jun 5, 2009 | 06:31 PM
ybturbo's Avatar
ybturbo
When an engine is disassembled all the consumable parts must be changed simple as that...
rex647
Mar 6, 2022 06:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
