vibration on over run
Old Jun 3, 2009 | 07:26 PM
studabear's Avatar
studabear
Default vibration on over run
my turbo cab'e got an annoying little rattle noise when I'm off the throttle, I first thought this was the exhaust but after removing it to check it today found it isn't. I've now found the cause, its the wastegate vibrating because when I push the actuator rod gently against the actuator the noise goes away.
So my question is is this down to adjustment or is the actuator on its last legs and has become weak?
Car is running standard boost with no issues.
Old Jun 3, 2009 | 09:36 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
ihad same problem and found it was exhaust as hasnt got the same mounting points as cab. i know u said it was wastegate/If your not having no probs with boost then i wouldnt wory too much bout it. CVH engines have got plenty of other noises to notice and worry about!
Old Jun 3, 2009 | 09:39 PM
studabear's Avatar
studabear
its bugging me so I will have to sort it
Old Jun 3, 2009 | 10:11 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
wind it in a couple of turns so its a bit tighter, wont changed the boost huge amounts
Old Jun 3, 2009 | 10:12 PM
studabear's Avatar
studabear
shortening the rod yes?
Old Jun 3, 2009 | 11:07 PM
orion_crazy_carl
orion=mini saff
yeah, think the rule aways was, the bar should cover half the hole, so it should be tight enuff to not rattle
Old Jun 16, 2009 | 05:27 PM
studabear's Avatar
studabear
cheers carl, finally had a chance to sort the actuator today, nice easy ten minute job even on the floor, the noise has gone and its boosting a lot better, there was no pre load on the wastegate whatsoever
Old Jun 16, 2009 | 10:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What plank fitted that?
The boost is not going hogher than what you are setup for though is it? Always best to be safe!
Old Jun 17, 2009 | 08:09 AM
studabear's Avatar
studabear
no mate its unchipped and i checked the pressure how stu@msd told me to years ago and its running 7psi 0.5 bar so all should be good
Old Jun 17, 2009 | 03:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Good man!
Fudgey
Sep 17, 2015 01:06 PM
talon1
Sep 15, 2015 10:27 AM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
gingeRS
Sep 4, 2015 06:29 PM
