gaz coilovers,how do you stop them...
Old May 30, 2009 | 03:29 PM
155lee's Avatar
155lee
Default gaz coilovers,how do you stop them...
from unseating themselves when you jack the car up?i have the car sitting at the height i want it at,when i jack it up i have to get my hand in there to make sure the springs are sitting in the cups and the cups are also seated properly.is there anything i can do or will i just have to put up with it?
Old May 30, 2009 | 03:31 PM
robbieg's Avatar
robbieg
Helper springs!
Old May 30, 2009 | 07:14 PM
cossie604's Avatar
cossie604
As said above, helper springs or lock wire the springs to the top cup (requires a tiny hole to be drilled in the cup though)
Old May 30, 2009 | 07:15 PM
cossie604's Avatar
cossie604
personaly, Id go for helper springs.
Old May 30, 2009 | 07:20 PM
Yep just 2.5lb helper springs, is easiest solution.
Old May 30, 2009 | 10:26 PM
AndyPen's Avatar
AndyPen
Ditto - have the helpers from AVO on mine... before I had the same prob as you.
Old May 31, 2009 | 12:04 AM
florent78's Avatar
florent78
where can you buy the helper springs ?
found nothing on ebay
thanks
Old May 31, 2009 | 02:48 AM
AndyPen's Avatar
AndyPen
Mine came directly from AVO
Old May 31, 2009 | 05:36 AM
cossie604's Avatar
cossie604
The correct name for them is tender spring, you'll also need a seperator, this goes between the tender and main spring. If you cant find what your looking for on the AVO website, just email them with your enquiry, ive found them to very helpfull in the past. Just tell them your having trouble with your main spring becoming unseated and that you want a low poundage tender spring and seperator to over come this problem
Old May 31, 2009 | 07:47 AM
Must admit when I jack my car up they settle straight back in perfectly with no help at all, I keep the top mounting greased though so it doesn't stick, would be better with little helpers in case I'm in a rush and forget to check sometime.
Old May 31, 2009 | 07:58 AM
STUCOS's Avatar
STUCOS
Helper springs lee,and it is also an mot failure
cheeRS stu
Old May 31, 2009 | 08:19 PM
155lee's Avatar
155lee
not if the mot inspector sees how mint the car is and doesnt bother with all them checks!it sailed through on tuesday,it got the tracking done 1st and the guy had a look underneath it and seen how mint it was so didnt bother putting it back up on the ramp.ill look into getting them tender springs,they look just the ticket.
Old May 31, 2009 | 08:23 PM
STUCOS's Avatar
STUCOS
Dodgie mot lee,thats what i like,
cheeRS stu
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
yatta
May 21, 2016 10:31 PM
DAZZER
Sep 30, 2015 08:43 PM
lime
Sep 25, 2015 06:56 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
