got a problem
Old May 30, 2009 | 12:24 AM
delterflier's Avatar
delterflier
Default got a problem
ok got in the focus earlyer at work to open the windows because of the heat but unexpectadly the driverside window wont go up and down.
checked the odvius but cud not find the problem
is there any commen faults?
cherrs for any help
john
Old May 30, 2009 | 12:13 PM
delterflier
anyone?
Old May 30, 2009 | 03:19 PM
RichieST's Avatar
RichieST
The drivers window failed on my old focus, was due to a microswitch breaking on the auto down feature. Required a whole new mechanism!
Old May 30, 2009 | 05:19 PM
delterflier
i think ur right because i had the door card off 2day and found nothing broken,nothing out of place so can only gess its the mechanism
i tell ya its one thing after another with this car
looked on ebay and thay are going from 30 quid and upwards so gess what i will be buying next lol
john
Old May 31, 2009 | 11:00 AM
RichieST's Avatar
RichieST
Make sure you get the right one though, as there are different ones depending on weather your car has auto down/auto up/global closure/3 or 5 door etc. Took ford a few attempts to get the right one for mine!
When you press the button can you hear a clicking from inside the door?
Old May 31, 2009 | 12:34 PM
mikey p's Avatar
mikey p
mine did this yesterday
i can hear the click. thank fook i hav A/C ahah
Old May 31, 2009 | 03:24 PM
delterflier
[quote When you press the button can you hear a clicking from inside the door?[/quote]
well i had both door cards of to compare passenger side made the ushal noise from a motor but driverside there was nothing.....the only clicking was from the switch
gud thing i have air con to
john
Old May 31, 2009 | 04:47 PM
RichieST's Avatar
RichieST
hmm, I could hear the motor clicking on and off when mine failed. Sounds like it could be something else, maybe the switch is fooked? Could be worth poking round with a multimeter before you go splashing out on a new mechanism!
Old May 31, 2009 | 04:54 PM
delterflier
worth a shot i gess
cherrs mate
john
Old Jun 1, 2009 | 08:26 AM
Weegi's Avatar
Weegi
motor failed on my diesel and on my frs it is a common fault with them but they are easy to change urself if you get 1 off ebay ohterwise u end up paying bout £120 in frauds and thats not with labour charges
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
