rear wheels rubbing
Old May 29, 2009 | 03:49 PM
rs-tuner's Avatar
rs-tuner
Default rear wheels rubbing
i have just bought another mint s2 turbo it is fully polybushed and sits on koni shocks and springs with 17 inch comp mos with 205 45 17 tyres. now the problem is that every time i hit a bump the rear tyres catch on the arch i have stiffened the shocks up to the max but it still does it what can i do to cure the problem cheers.
Old May 29, 2009 | 03:52 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
trim the arches is the only big cure really!
Old May 29, 2009 | 03:56 PM
lead_foot's Avatar
lead_foot
is awesome
Roll the arches
Old May 29, 2009 | 04:22 PM
orion_crazy_carl
orion=mini saff
still got the plastic kit tho, and tht wont roll lol
Old May 29, 2009 | 04:29 PM
lead_foot's Avatar
lead_foot
is awesome
They will if you heat them up. LOL
Old May 29, 2009 | 05:17 PM
rs-tuner's Avatar
rs-tuner
dident want to do either of those anything i can do without hacking the car
Old May 30, 2009 | 09:10 PM
slimwynn's Avatar
slimwynn
what about a different tyer size
Old May 30, 2009 | 09:13 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
get a more stretched tyre or bring ride height up mate
Old May 31, 2009 | 10:15 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Run 195's not 205's.
Old May 31, 2009 | 03:15 PM
studabear's Avatar
studabear
try 205/40r17's there a lower profile
Old May 31, 2009 | 05:13 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Mine used to do this i just turned 4mm of the face of the disc where the wheel butts up to and this allowed the wheel to sit further back away from my arch
Old May 31, 2009 | 06:43 PM
rs-tuner's Avatar
rs-tuner
i will try these suggestions out cheers guys
Old Jun 1, 2009 | 03:58 PM
jamieRST's Avatar
jamieRST
arches rolled m8,or smaller wheels as said,is the same reason im getting rid of my 17s and going for 16s.anyone intersted pm me.tsw kaylamis,they dont make them anymore.
jamie
https://passionford.com/forum/restor...2-project.html
Old Jun 1, 2009 | 04:08 PM
robj20's Avatar
robj20
I have those rubber coil spacers on mine and running exactly the same wheel size, no rubbing even with two up.
Old Jun 1, 2009 | 07:19 PM
JesseT's Avatar
JesseT
How much space do you have between the wheel inner face and the shock absorber? Sounds like your ET is too small? Should be around 40mm, and the 205 really is the maximum that will go in without hassle.
Old Jun 1, 2009 | 08:53 PM
Oranoco's Avatar
Oranoco
You're on 205/45/17's and on an ERST you need to be on 205/40/17's this will either go a long way towards sorting you out or even cure it alltogether.
rs-tuner's Avatar
rs-tuner
thought about them i will give these a try what offset do you run
Old Jun 1, 2009 | 08:56 PM
rs-tuner's Avatar
rs-tuner
sorry tyres are 205/40/17
Old Jun 2, 2009 | 05:36 AM
robj20's Avatar
robj20
Dont know, but i bought it and it was rubbing the rears so stuck these on problem solved. I will be dropping to 40's at the next tyre change as well.
Old Jun 2, 2009 | 06:01 AM
JesseT's Avatar
JesseT
If it's definately catching the rear arch, and not bottoming out on the wheel well, then it's not a question of the tire having too big a diameter, but just sitting too far out.
Old Jun 2, 2009 | 05:01 PM
rs-tuner's Avatar
rs-tuner
so what offset should the wheels be cheers
Old Jun 2, 2009 | 05:52 PM
RSandy's Avatar
RSandy
make sure to check exactly where it is rubbing. i spent ages trimming/rolling my rear arches only to find out 90% of the rubbing was due to contact with the lip of the rear bumper where it sits inside the arch. i trimmed as much of this back as i could without ruining the mounting holes, and problem solved. and mine was sat stupid low on 17x7" rims, 205 40 17 tyres, and i believe et38
Old Jun 2, 2009 | 06:57 PM
JesseT's Avatar
JesseT
ET 38mm is pretty much spot on for a 205mm width tyre. The narrower the tyre, the less ET you can run.
Old Jun 2, 2009 | 07:08 PM
rs-tuner's Avatar
rs-tuner
the wheels are et37 and defo rubbing on the inner arch might get some smaller wheels
3drRich
Sep 13, 2015 07:32 PM
YODI
Aug 30, 2015 01:12 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
borboyous
Aug 22, 2015 11:17 AM
RsS2daz
Aug 14, 2015 05:26 AM
