identifying a pipe
Old May 24, 2009 | 10:36 AM
DAVE WRC's Avatar
DAVE WRC
Default identifying a pipe
i have a f reg saphire cosworth i am trying to identify a pipe i believe is leaking water its directly under the the injectors and fuel rail just above the oil filter its a black one and runs parrarel with the direction of the engine anyone know what the pipe leads to and from its difficult to see without ripping half the engine out
cheers
Dave
Old May 24, 2009 | 10:47 AM
DAVE WRC's Avatar
DAVE WRC
Oh and the pipe only seems to leak when i put the car back in the garage after i have been out in it ?
Old May 24, 2009 | 11:59 AM
jon@work's Avatar
jon@work
A pipe runs from the heater matrix around the back of the head to the modine (between the block and oil filter) and then from the modine to the rear of the head on the inlet side. It'll be one of these, or the modine itself has rotted.
Old May 24, 2009 | 01:30 PM
As jon says, not too bad to get to from underneath, can get poly ones as well for this.
Old May 24, 2009 | 03:21 PM
DAVE WRC's Avatar
DAVE WRC
K managed to get to the pipes to see its the pipe that goes from modine to the rear of the head on the inlet side its split justabove the dubile clip
Anyone know where i can get one from
Old May 24, 2009 | 04:28 PM
You can sometimes get away with just lopping the split bit out and stretching a bit, temporarily.
Don't know if std ones are about anymore, but sure begay will have some poly ones, maybe Matt Lewis 01543 484488.
Old May 24, 2009 | 09:21 PM
AndyPen's Avatar
AndyPen
If it is too tight you can cut it behind the block and insert some plumbers copper pipe with a couple of jubilees to extend it. That's how I found mine when I took it apart and I didn't even know about it! Obviously a new hose makes sense and I think Samco even do them in black now???
Cosnada
Jan 7, 2016 05:30 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
