What thread is the inlet manifold for dump valve/map sensor?
Probably all the same for cossies, but it's a 2WD saph if that makes any difference? Took the bloody thing out now i've lost it!
Yes i most certainly am!
I was taking the ACT sensor out and i had to remove the plastic adaptor fitting for the Map sensor and dump valve but i've misplaced one (hopefully not in a dangerous place
) and i need to put it all back together again.
