low oil pressure when worm
hi
ON my 3dr ,when engine is warm and at idle my oil pressure drops below 30 psi.i'm running stage 3 is this normal,if it is'nt what can any of you recommend
to remedy this.cheers any advice gratefully received.
oil pressure will drop when the engine is hot, even worse if its been driven hard
what grade oil are you using?
is your oil pressure mechanical?
has it always been at this pressure or suddenly dropped?
is it a new build or done a few miles?
does the pressure increase when you rev the engine?
I wouldn't be worried about 30psi at idle either, as said so long as picks up it's fine.
The oil gets very hot on cossies especially after a thrash, a oil cooler will help pressure as it keeps it cooler, as will using a good oil/grade like a 50 or 60 weight.
I've found that cheaper oils give less pressure hot one i can think of is the commer (spelling?) which a guy i know had in his cossie and run 20 psi hot
LOL at Matt
Matt you buying and selling again?
Paul
LOL at Matt
Paul
i think my gauge is shite in mine, it sits at about 15 psi when its hot, and only ever goes to about 40 when revving!
I'm pretty sure if it was that low, my engine would be knackered by now.
basically mate if it dont start tapping and knocking on idle and youve got over 15-20psi you should be fine, i run pattern bearings in mine and after a very hard drive on idle it goes down as low as 25psi, thats with a hp oil pump on mobil1 15/50
mines 45psi tickover 60 psi above 2 grand when hot and has always been this good allthough saying that i was out thrashing before and it now has oil all over the bulkhead and underside of the car! job for tommorow methinks!
Just had a rebuild and have a high pressure oil pump spring
I've got an electric oil pressure gauge, using valvoline 20/50 for running in, it's winter here at the moment, and I see up to 80psi on startup, then as low as 20psi at warm idle and about 40-60psi on cruise
Mine sits about 30psi at idle when the oil is between 80-> 90 degc
After a hard run it drops to about 26/27 when around 105 deg
Lowest I've seen is about 24psi after a few laps at Anglesey - think oil was about 115/120.
It recovered as the oil cooled
That's on Silkolene Pro S 10/50.
I noticed it used to run slightly higher psi on Castrol RS/Edge 10/60 ( when it used to be popular ). Think the reason for that was the molecules get chopped up or similar - Mike R or Oilman or Rod Tarry could probably tell you the reason.
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
