spec-r breather question
Old May 14, 2009 | 05:19 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
Default spec-r breather question
evening folks,have a quick question regards my breather as follows
i have a spec-r one with catch tank,as i am rebuilding the bloody thing i have got breathers to either side of the block,now i did intend to also put one into the top of the cam cover but could i instead pipe a return to the sump under the oil level & still run one to the catch tank
oh by the way the seperator has 4 ports 1 on the left,2 on the right & 1 underneath (which i propose to run to the sump)
am i wasting my time thinking this
ta
Old May 14, 2009 | 05:58 PM
AndyPen's Avatar
AndyPen
Some of the the touring cars did that to the sump. Mine breaths from the front of the sump - near the oil pump. Heres a pic from the build that shows it clearly.
Old May 14, 2009 | 06:07 PM
cossiedave's Avatar
cossiedave
dont put the return to the sump with the spec r breather it will pump all the oil from the sump fill the catch tank up and come out the filter on the tank i only know this as i did it
Old May 15, 2009 | 06:16 AM
Cragrat's Avatar
Cragrat
sit boo boo sit
ahhh bugger now i`m confused,admittedley the easiest way is gonna be to not return it to the sump & just vent the block with a catch tank
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
