zetec turbo
if u wanna use a festa RST inlet manifold on a zetec 16v turbo conversion , will the loom and management go straight onto it once the inlet and exhaust have been bolted onto the head? or is there other things to consider? any help appretiated
cheers
cheers
Sorry mate, should have read it propperly!
Well, Fiesta Turbo will pretty much plug into all the sensors and run...however youll need it mapped and injectors, MSD can do this for you, Lee @ Fusion has juts has his Zetec turbo mapped by them!
At the end of the day, FRST is cheap to source loom and ECU etc, but it needs mapping, like any management for the Zetec turbo really!
