Nitrous oxide
As above when i finish putin cash in my engine wanna run nos, not the boost style where u push the putton and away u go, but the kind where your engine is always running it i seen this on fifth gear. how much could this cost?? money is not a bother.
For 100bhp jets, it would cost 50p a second to run all the time, are you sure you want it running all the time?
I think you misunderstood them, what they used was a throttle switch so it only ever put nitrous in at full throttle.
About 600-1000 is a good ballpark for the kit, and as per my comment about, 50p a second in use if its for 100bhp.
www.noswizard.com
Thats the only place I would buy a kit from (same people who did the 5th gear test funnily enough, and the top gear XJS that clarkson had)
No, it hits only when you press the throttle fully open generally, although you can have it rev limited too.
So at full throttle acclerating flat out at 4000rpm you would have nitrous injected, but at 5000rpm on a fast cruise down the motorway it wouldnt be injecting any.
There is no point injecting it anywhere other than at full throttle as anywhere less than full throttle you can have more power for free just by opening the throttle further anyway.
Any one have experince running this on a CVH turbo? Would be interesting to here about it!
I'm guessing the internals would need to be uprated to take the BHP just like if it were BHP made without NOS? So really only about 220-240bhp on stock internals. Also probably a gearbox killer too?!
Rab, let us know how you get on!
Graceland
20
Jun 21, 2005 08:34 PM
TheBishMan
May 16, 2005 04:52 PM
SřrenBM
Oct 25, 2004 08:54 PM
