Rover 214 problem
Old May 12, 2009 | 02:24 PM
BM08's Avatar
BM08
Default Rover 214 problem
Forget about the car model
So anyway, if its using water alot(like needing it every other day) but theres no sign of leaks, would that point to head gasket?
Old May 12, 2009 | 02:25 PM
C4llyT's Avatar
C4llyT
Got to be going somewhere..
Difficult to start from cold, and a lot of steam for a while?
Smelt the exhaust for antifreeze? Probably just water though by sounds of it.
Old May 12, 2009 | 02:26 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Its a rover 1400 16v??? Its the head asket mate, its what they are known for, Get the gasket for the freelander when and if you do it, Its a heavier duty revised item and works a lot better
Old May 12, 2009 | 02:27 PM
BM08's Avatar
BM08
No problems starting as far as i know(my sisters car) just the fact its using alot of water
Old May 12, 2009 | 02:30 PM
Less.'s Avatar
Less.
having a mid life crisis
Yep had the same problem on a rover I had then the head gasket went
BM08's Avatar
BM08
I assume its a 16v, but yes 1.4 and its the bubble shape one on a v plate
Old May 12, 2009 | 02:31 PM
BM08's Avatar
BM08
How long did it last then? my sis has been using it daily like this for weeks now.
Seems like its on borrowed time then
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
K-Series engines LOVE head gaskets. They are a practically a service item.
Old May 12, 2009 | 02:32 PM
BM08's Avatar
BM08
we know that yeah, but i was just double checking that her engine is buggered thats all
Its not done many miles either, only about 70-80k i think
Old May 12, 2009 | 02:35 PM
smila's Avatar
smila
have you checked the water pump?they all ways leak on them
Old May 12, 2009 | 02:39 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
head gasket, no question, more common than cossie HG's!!
get the modified gasket, new bolts and dont move the car when the bolts are out!!
Old May 12, 2009 | 02:40 PM
john.n's Avatar
john.n
Water pump also means changing the timing belt-unless you have recently done it, you can more or less garauntee it will be the head gasket though. The "K" series engine is a piece of shite.Even with the upgraded gasket and all new bolts etc. You could easily spend £700 upwards and then be doing it all again next year. Get rid of it, save your money and buy something else! john.n
Old May 12, 2009 | 02:42 PM
Christian and Beccy
#1 in Spelling Club
Think Rainbirds Freelander had munched its way through a handful of gaskets by that mileage.
Old May 12, 2009 | 02:46 PM
BM08's Avatar
BM08
well its her car not mine so all i can do is tell her, its up to her if she fixes it, or runs it until it goes pop and buys a new car.
Personally i think she should get another car, but its her choice
Thanks people
Old May 12, 2009 | 02:57 PM
RichieST's Avatar
RichieST
Blimey I'm surprised its lasted even 30k without blowing it!
Old May 12, 2009 | 03:01 PM
BM08's Avatar
BM08
I dont think there THAT bad surely
Old May 12, 2009 | 03:05 PM
john.n's Avatar
john.n
OH YES THEY ARE!!! john.n
Old May 12, 2009 | 03:06 PM
Martin Hadland's Avatar
Martin Hadland
Lol at all the HGF suggestions!! If its simply using water then the first thing I would check is whether the inlet manifold gasket is leaking by either numbers 1 or 4 cylinders as this is a very common problem on plastic inlet manifold models, take out the spark plugs and compare the colours of the ends.
Old May 12, 2009 | 03:10 PM
BM08's Avatar
BM08
Really? oh right, might not be dead yet then!.
Will have a check, or get her bloke to check it, cheers mate
Old May 12, 2009 | 03:11 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Yup, they can go as low as 15k! And unless the head is skimmed properly (or even replaced) can go again even with a 'better' HG! Shit cars, shit engines.
Old May 12, 2009 | 03:24 PM
The Youth.'s Avatar
The Youth.
they can't be that shit I mean plenty of people bought them and if there as shite as you say then rover would have gone bust by now....
steve
Old May 12, 2009 | 03:28 PM
cabrio zo's Avatar
cabrio zo
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
My bosses was replaces circa 13k miles I think (MGF)
Z
Old May 12, 2009 | 03:37 PM
B16 Will's Avatar
B16 Will
its all about the 5 pot
I did my dads ZR160 on 17k, 35k and 70k, as said, make sure you fit the landrover gasket with the sandwich plate on top of the gasket, skim & pressure test is vital, make sure its got metal dowls fitted (they came with plastic ones on the early type), pretty straightforeward job. Hour off, hour on.
Old May 12, 2009 | 04:39 PM
Rab's Avatar
Rab
Fucking superstar........
As Martoon has said, make sure the plastic inlet fannymould isn't leaking.
Old May 12, 2009 | 04:55 PM
foreigneRS's Avatar
foreigneRS
Testing the future
was helping a mate do his on his elise at the weekend. i would rather have done this for an 5 hours
AJC
Oct 1, 2015 06:47 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
