Oil/petrol in boost pipes...
Swapped coolers yesterday and I have an oily substance in my boost pipes! Very weak tho and stinks of petrol. Not a good sign I guess. Old cooler has oily mixture in too. I had my turbo refurbed a while back and engine transplanted a few weeks ago, so not sure. Is it turbo failure? I'm running no boost due to new engine, so can't tell you how the turbo is performing.
Fueling meter needs work tho, so could that create this mess? Top boost hose, crossover pipe and throttle body clean... All bottom boost hoses oily only.
Nah, not much oil really. 1cm deep in a cup, if that. So Its all down to the metering unit then? Breather is Bailey, but old engine used to breathe heavy so probs old stored oil?? How would I clean out the old cooler? Degreaser?
No it's down to the breather setup returning to the metering unit (assuming that it stil is), a lot of us breathe to atmosphere and block the return off on the metering unit, that way only clean fresh air get's into our engines and you dont get the mess you've found in the boost pipes or IC!
had someone tell me that my engine was going to die because i had oil in my ic. two rr tuners and 30k miles later and its never been mentioned since. dont worry to much mate its pretty common.....not saying its a good thing because it provokes det
Cheers for all the replies guys
The engine has just cleared 1,200 miles of gentle run-in, so the concern of provoking detination is minimal considering i aint giving it any beans until she's placed on the rollers and set-up by a pro.
As for the breather set up, i did have it aired to atmosphere when it was my old engine... but i was unconvinced doing it that way as all sorts of problems happened with it that way! Now with my new engine, i plumbed it back the way Ford designed it - into the metering unit.
So aslong as i keep on top of it and check regulary for increased amounts, i should be cool?
Thats good news! I sooooo cant afford anymore problems at the moment
If it does increase, would a catch tank be worth while?
This is slighlty confusing tho because its only been a few weeks since i changed the engine for a new one..so could be caused from old engine.. I'll just keep an eye on it i reckon.
+1 regards Det!
), but you shouldnt have enough to worry if it's a fresh engine.Some is normal though so if it's not a lot I wouldnt worry.
Its not a lot no, plus it could just be left overs from the old engine... I dunno.
When i aired to atmosphere on the old engine it created bellows of smoke (you may remember my thread?) and then the engine decided to fill with mayo. It may just be a coincidence, but it all started going wrong from blocking the metering head and fitting a little filter to the breather tank.... I'll get it booked in somewhere to take a look early next week anyways
Oh yeah I do rememebr your thread!
I run vented to atmosphere and have no smoke/oil from my filter and all is well, lots of other people do on here too so it's not a problem, but retuning to metering unit is fine just wont make quite as much power as if you didnt thats all.
what i might do then is just see what the tuner says when setting up. If he says try it again, i will. Need a new filter tho... the last engine fooked the last one lol
I too had problems with the car smoking when i was on mfi and breathed to atmosphere so put it back lol, never had any problems and personally can't see you getting any power gains by breathing to atmosphere. On omex now so doesn't really matter either way now
You get gains because by removing the oil content from the charge air you raise it's resistance to Det which allows more ignition advance or a leaner mixture or both.
But it isnt much as I said.
I dont know why but my car didnt like the vent to atmosphere method at all. I bunged the return to metering head and vented the breather to atmos, ran like a bag of shit, this was a brand new engine with all new breather pipes and spec-r breather. I had to run venting back to metering head. Ive recently removed the ic and pipes and theres loads of oil in there, im putting it down to the small spec-r breather not been up to it, ive got a new bailey one to go on when it comes to it. Just cant work out why it hated been vented to atmos so much???
We did, it was at NMS for its final setup and we tried to remove the metering head feed and vent to atmos and it wouldnt have any of it. im pointing my finger at the spec-r breather due to its size but I dont have any hard facts on it.
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
