Rs smokeing
When i start my rs theres blue smoke then after a min or so its white, after she has warmed up its fine what can this be caused by guys
All advice would be very helpful
Thanks Rab
Thanks Rab
Valve stems mate.
Its a 30 min job.
You need a CVH valve stem tool (£7.20 from Burton power)
Set of valve stems (about £10)
rocker cover gasket (about £3-5)
A 19mm ring spanner
A 13mm socket
If you have a small magnet this can help with removal and refitting of the collets.
Very very simple job. If you need pics i can link you to my rs16i engine build i did a few months back.
Its a 30 min job.
A 19mm ring spanner
A 13mm socket
Steve Escos
Oct 1, 2015 06:57 AM
