Air injectors
Old May 8, 2009 | 08:55 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Default Air injectors
I did ask this a week or so ago,
Are these the right way round if so which pipe goes to where.
Many thanks.
Steve
Old May 8, 2009 | 08:57 PM
J1mbo's Avatar
J1mbo
B1mbo
top to actuator, bottom to compressor housing
Old May 8, 2009 | 09:03 PM
Moonstone Steve.
Thanks short stuff
Out of interest how come some people have the injectors pointing the other way.
Steve
Old May 8, 2009 | 09:06 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
does it matter if they are upside down as long as the relevant pipe goes to the same place??
Old May 8, 2009 | 09:08 PM
Moonstone Steve.
Dont know m8, wot is the bleed hole for in relation to which way around they are.
Steve
Old May 8, 2009 | 09:23 PM
Psycho Warren
Carbon Crazy
well im thinking it shouldnt matter anyway as its not like a normal fuel injector where the spray pattern is important and wouldnt work the wrong way round.
Old May 8, 2009 | 10:33 PM
J1mbo's Avatar
J1mbo
B1mbo
pmsl at short stuff
i cant see a problem with it being upside down, some of the rally boys ran them like this ! personal choice i guess
Old May 8, 2009 | 11:03 PM
Evey's Avatar
Evey
noob to turbos, but what do Air Injectors actually do?
Do they just leak boost in a controlled manner?
Old May 8, 2009 | 11:07 PM
J1mbo's Avatar
J1mbo
B1mbo
they supply the actuator with air, the actuator then acts on a "gate" if you like to allow air to bypass the turbo or go through the turbo
the air comes from the front of the turbo, into the air injector, through the air injector and as above to the waste gate
the ecu controls how much air goes through the injector, this then effects what boost you have
hope that helps a little
Old May 8, 2009 | 11:13 PM
Moonstone Steve.
A+ young man
Steve
Old May 9, 2009 | 11:01 PM
Evey's Avatar
Evey
thank you
Old Jun 9, 2009 | 08:14 PM
focus 4x4's Avatar
focus 4x4
wheres the best place to get a set of these air injectors?
Old Jun 9, 2009 | 08:40 PM
Turner RS's Avatar
Turner RS
To give information, many tuners charge for a twin injector setup when in reality only one is used. Fuel injectors burn out, gas injectors should be used.
You can tell by looking at your "air" injectors, you will see different part numbers on each, this confirms an owner has been conned. LOL.
Old Jun 10, 2009 | 12:13 PM
WD Pro's Avatar
WD Pro
Two gas ones in mine
Old Jun 10, 2009 | 12:17 PM
Moonstone Steve.
Two gas ones in mine aswell.
Steve
Old Jun 10, 2009 | 04:08 PM
As stated correctly they need to be gas injectors, BOSCH have NEVER made ANY air injectors, all the ones I've seen sold as air injectors are CNG injectors, as to whether they will overheat under prolonged hard use is anyones guess, but they don't seem to.
Could also use a amal valve.
Old Jun 10, 2009 | 06:51 PM
focus 4x4's Avatar
focus 4x4
Heres my Air injectors , can anyone identify if they are the real deal or not.
both injectors are identical and have the same part number of M590HF 9381AA on one side and B..1223..02 on the other side of each injector.
Old Jun 10, 2009 | 06:54 PM
J1mbo's Avatar
J1mbo
B1mbo
are you sure its not ms90 ? as thats the group a number im sure
Old Jun 10, 2009 | 07:08 PM
focus 4x4's Avatar
focus 4x4
The number defo statrs M5......
Old Jun 10, 2009 | 07:56 PM
Turner RS's Avatar
Turner RS
If they are both the same then they will both be working.
The normal used gas injector really only needs one due to its flow capacity.
Old Jun 16, 2009 | 11:57 AM
WD Pro's Avatar
WD Pro
These are mine :
You can make out the part numbers on the box's - I trust they are correct as they were supplied by Matt Lewis
Old Jun 16, 2009 | 03:35 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
a pair have always been used in parallel to obtain the correct impedance for the weber ecu
depending on the pair of injectors used dictates whether an in line resistor is required.
you cannot obtain the correct impedance for the weber ecu with one injector of any type
Old Jun 16, 2009 | 07:40 PM
richard youll's Avatar
richard youll
dazc on here supplies them on here single or twin set up identical to the 909 twin set up with loom ready to plug and play very very nicely made aswell!!!
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
